Dimu
- May 7, 2016
My TU-8500 has TDK pot which is better than ALPS. It was not as simple to install it as in TU-8200.
That's ok, the results are still fantastic!TU-8500 does not have enough space for bigger volume pot..
Righto, thank you, Is it a size issue with the TDK pot? The stock one is quite compact. Was it a big job, or just required a bit of care?My TU-8500 has TDK pot which is better than ALPS. It was not as simple to install it as in TU-8200.
Are the upgrade boards and components available for the TU-8200DX now? When will Lundhal transform upgrade be available?
ELEKIT will not offer upgrade PCB for TU-8200DX. The Lundhal is next spring. We are working on TU-8800Can we have an answer to this question please?
