ProfessorC1983
I ended up going with the Zu Omen MkII's as well -- so far they're an amazing pairing with this amp! Really floored by how much oomph they can put out with just 4W of triode power, and the forward sound signature balances well with the tube warmth from the amp.
I also talked myself into a pair of NOS GE 6L6GC's while they're still available... huge improvement over the stock tubes! I already have the itch to roll more (thinking I may try the Winged-C EL34's next) but I need to get my preamp situation figured out first. Still thinking a DIY solution is best for my needs since I can't afford something like the ModWright.
On that note I had a couple of questions for anyone on the board who's still paying attention:
1) I'm trying to find the input impedance spec for the Elekit. The volume control I plan to use in my DIY preamp (Joshua Tree attenuator) has a fixed low output impedance of 750R... wondering if that is suitable to drive the Elekit passively or if I would need to add an active tube buffer stage in between?
2) Once I get the attenuator preamp working my plan is to remove the volume pot from the Elekit completely since I won't need it. Has anyone done this before? I assume it would just be a matter of desoldering it and adding either fixed resistors or wire jumpers across the 2 signal paths, but are there any gotchas I should look out for?
