As an aside, can anyone get into the Effect Audio website, getting back malicious link flags. I've not managed to get in for ages. Using Mailwarebytes, Kaspersky and even BT are reporting issues....!
Am based in England, UK as well
I just successfully loaded the website at the following address: https://www.effectaudio.com
Not sure if deleting/resetting cookies in your browser would help?
Hi @Seyley, maybe you can try clearing your cache? See if it helps?? I've tried logging in with chrome and safari, didn't experience any problem at all. https://www.effectaudio.com/
I ordered a cable a month ago.. They were a bit late in shipping it (12 days) but the tracking number only seems to work on the Singpost site not my domestic service.
Anyone else experience this? The cable apparently landed in Canada a week ago but it's still not here and tracking through Canadapost doesn't recognize the tracking number.
Maybe it's not sent in a way that is trackable but I haven't heard back from EA so I thought I'd ask here.
Not truly worried yet just typical impatience.
Thanks for the help. Turns out that the tracking doesn’t work past reaching Canada so it’s just typical slow mail service. Hopefully it’ll be here soon.
I am looking for a pair of upgrade cables for my SE5WAY-ult monitors, selecting from either Horus or Leo-ii-octa (same price range). Which one is better? Any advice would be appreciatable. Thanks.
Both cables are highly competent with one and other and to be honest and it's really a tough call to choose between this 2 models. Ultimately it boils down to what you're sound you're looking to achieve as i felt that the projection of "Horus" inclines towards a neutral tonality , it enhances the transparency and resolution of the sound it projects. Whereas for the Leonidas II, it sounds thicker and fuller, with incredible texture highlighted on the midrange.
For comfort wise, The "Horus" 4 wire configuration will definitely be more favourable because you can't feel it's presence when you don the cables,It's that comfortable. The "Leonidas II" on the other hand would be slightly heavier but not much of a concern as it remains supple. I hope this explains, Cheers!
Thank you for your reply. I'd take that the horus is an uncolored, balanced cable, while the leo-ii has an extended, forward, aggressive mid, is that correct?
IMO, I wouldn't use the words "aggressive" or "forward" to describe the mids on the Leo II Octa. When Paul says the LeoII mids are "thicker" and "fuller" that is accurate. It's not that the mids are necessarily more "in your face" on the Z axis. They take up more space "laterally" in the X,Y axes. Also the Octa adds more weight all around especially in the mid-bass downward.
At the same time the Horus is not thin or strident sounding at all, merely transparent. It also has a a kind of fulness, that, to my ears, is more natural and more precisely follows the timbral contours of the source sound.
The choice, of course, will come down to your system and tastes, whether you're looking a thicker or clearer sound.
