- Sep 20, 2016
Hi, I am back here as engineer, and please bear with me, who sees this cable matter as a deep science.
IEM is regarded more likely as extension of the cable itself because of the resistance ratio of IEM to cable being relatively lower than full size headphones, that is 16 to 1 ohm (?) for one wire and 16 to 0.25 ohm for 4 wires.
Inductance ratio (phone to cable) is obviously lower than full sized one, which is 5 uH (?) to 5 uH for single wire and 5(?) to 2 ~ 3 uH for more wires. Because inductance can not lowered as much as that of resistance by increasing wires.
With respect to these view, cable can be more effective filter to IEM than to full sized, which can be regarded independent motor due to those high ratio.
Consequently IEM is more subjective to number of wires and hence the impedances than full size headphone.
This view is analytic as are usually found in science realm.
However holistic approach done here should be respected and appreciated.
I respect your views, which give me a view of deep science.
Probably this topics are already done in this thread which I didn't read through and sorry.
I might conclude that the more wires the better due to those humble observations above.
Vendor like Effect audio can see more deep science for this.
Are you guys seeing what I predict?
Thanks
I absolutely respect your views and opinions and i concur mostly with your calculations. With regards to your observations, you're mostly right than wrong. You have no idea how much trial and error that we have went through and the amount of wastage that we run through in our R&D just to derive at a similar conclusions and to understand the concepts of cable / materials and other controllable variables that affect the sound. However, there is one aspect that we've never been able to pin down onto - "Psychoacoustics". We've visited a rather good number of scholars and universities but there seems to be no available method to measure "Psychoacoustics". Ergo, without having a accurate control over "Psychoacoustics" we still exhaust a hefty amount of wastage during our R&D and new development.
Wondering if you have any views on that?
@EffectAudio
Curious what you use to glue the covers of the 2 pin connector to the connector itself. The right sided came off my Lionheart about the third time I was switching IEMs.
We uses 2 different type of glue - "Weicon" Contact Cyanoacrylate Adhesive (VA8312) and Loctite 3090. Would you like to send to us to have it rectified by us?
Their 2-pin covers have been hit-and-miss for as long as I can remember. Eric tells me the supplier of the black plastic component is the one that’s inconsistent, so I hope EA either crack down on them or ditch them for someone else. My Leo II’s have been rock solid, though, so it’s not impossible.
I understand that this issue has plagued us for a good amount of time now. Yes, we're actually on the discussion of new 2Pin design [also on different 2pin materials ] , so yes, we're definitely ditching them for a better partner.. I hope...they dont read headfi lol.
-Eric
Stay updated on Effect Audio at their sponsor profile on Head-Fi.
