Armaegis
Modern Modder Man of Manitoba
HTML... uphill, both ways!
- Oct 18, 2009
I'm thinking just using red nail polish right off the bat would work better.
I used some red acrylic paint that I got from the dollar store. In retrospect, this was a really bad choice. I should have used modeling paint (which is enamel I think?). The acrylic was all splotchy and uneven, even after two coats, and had a very rough feel to it that would scratch off easily. My solution to this was to coat it with clear nail polish. Why nail polish? Because I didn't want to head back out to the store and buy a whole bottle of varnish for such a small project.
So anyhow, three coats of nail polish later (with at least a day or two to properly dry between coats) and it actually turned out really well. It smoothed out the splotchy colour and made it all smooth and shiny. I unfortunately goofed on a couple spots and you can see red on the foam. Amusingly, it's the same red splotch on both sides, so at least I'm consistent.
Project time: about a week. Actual work time (painting and paper cutting): maybe 3 hours.
The only downside is that now I won't have a PX100 anymore. Hmm, maybe I should get the 100ii...
Yeah if I were thinking ahead that would have been better... and by varnish, I guess I was thinking of a poly coat of some sort. I don't really know much about painting... *shrug*
I've seen a few tutorials since then so if I were to do this again I would approach it completely differently... then again my cost for the original paint job was literally $2 ($1 for the paint, $1 for the brushes). To do it "properly" would cost significantly more than $2.
If I were to spray paint now, it would be clean -> sand -> clean -> prime -> paint -> paint -> paint -> poly -> poly
On the other hand, girls appreciate a hand painted gift much more...
