firstlorp
- Oct 26, 2010
Jon L said:/img/forum/go_quote.gif
OK, here's some further info from Alex:
"After the low pass filter, the analog signal will be fed to the tube or ss amp stage by a selector switch. By tapping this switch, the signal goes either to the tube or the ss stage. The tube will be a single tube amp stage and the ss will be opamp. The tube will be a 12AU7. To conclude, the tube and the ss stage they stand alone each other, you only choose which one to put out (amplify) the final analog signal.
I hope the above helps.
Oh by the way, the shipping is about 2-3 month as this is the first lot and I hope everything runs smoothly
Cheers !
Alex"
Thanks for your analysis! It is just the solution for my problem, Nice writing, Now I understand more about it.
