Jun 25, 2013 at 11:39 PM Post #1,111 of 1,167
SM3 would be best sound-wise but they are pretty fragile. Check out the T Peos H200 or another TF10.
Do you think the T Peos H200 would be durable and sound close to the sm3? Because this is the first time that I have heard of the company (I know, I'm a noob). Also, would the sm3 standard cable last longer than the triple fi standard cable that was always breaking because I want to make sure my purchase lasts me a very long time.
Jun 25, 2013 at 11:47 PM Post #1,112 of 1,167
I would check out the ortofon EQ-5. They are touted as being clones of the sm3 but a lot more durable and they look better IMO.
As far as cables go I can't comment on the sm3 but overtime nearly any cable would go and when it does I would go straight to BTG-Audio and have them recabeled with some top of the line wire.
Jun 26, 2013 at 12:24 AM Post #1,113 of 1,167
Thanks for the suggestion. I am looking in to the EQ-5 and noticed that there is an EQ-7. Would you consider the EQ-7s to sound even better than the sm3
Thank You
Jun 26, 2013 at 7:55 AM Post #1,114 of 1,167
Thank You
I really don't know. I would try asking in either appreciation thread. I know both are held in high regard.
Jun 26, 2013 at 1:06 PM Post #1,116 of 1,167
Jul 4, 2013 at 2:15 AM Post #1,117 of 1,167
Hey guys. Could you recommend me an upgrade cable for sm3 v2? My current cable died. One side of the monitors emits no sound. Budget range like $100ish and I prefer clarity and a little bass but not too faint.
Jul 4, 2013 at 7:40 AM Post #1,118 of 1,167
in that price range you can spend a little more and get  the baldur mk3 or something similar i bought this one ttp://www.ebay.co.uk/itm/IEM-Upgrade-Cable-for-Westone-JH-Audio-UE-Custom-/271144319609?pt=US_Other_MP3_Player_Accessories&hash=item3f2175fa79  to my sm3v2 and to my fischer amps fa 4e i didn't receive it yet but the reviews are good and only in sound it performs above their price, check the reviews of the effect studio pearl cable its about 65$ plus shipping.
Jul 4, 2013 at 7:46 AM Post #1,119 of 1,167
You guys do realize the SM3 v2 socket pins polarity are in reverse to Westone don't you?
Westones + / - layout is like this.
SM3 v2 are in reverse, so anyone out there running Westone upgrade cable is using their SM3 in reverse phase. I have tested this many times with a multimeter. Try it yourselves, check the positive / negative pins against your stock SM3 cable.
Jul 4, 2013 at 8:02 AM Post #1,120 of 1,167
You didn't receive the cable yet or the amps?
Jul 4, 2013 at 9:42 AM Post #1,123 of 1,167
Sorry, as I'm quite new, how do we know which cables are compatible with the V2s?
Basically, you can use any Westone cable that doesn't have pre-moulded ear hoops, because you can flick the plugs around. Any Westone cable with pre-moulded ear guides prevents you being able to switch the polarity the right way. Still you should be checking with a multimeter against the stock cable when hooking up the new cable.
Jul 4, 2013 at 7:00 PM Post #1,124 of 1,167
My SM3 V1 had been upgraded in January 2012 to V2. A few weeks ago I realized both sides of my SM3 V2 has gotten distant and veiled. I now suspect dust and dirt accumulating in the earpieces might be the reason for this. Is there an easy way to clean the inside of the earpieces? Is there a guide on how to open and clean the SM3? Any suggestions?
