koonhua90
- Jun 1, 2009
^^ same for me. The treble was recessed at first, but not anymore after some 20 hours of listening.
That sounds great man, how do they compare? I am eager to know the difference between the two, if it isn't that big, I'll just buy another clip.
Depending on tip, bass can get as low as the Copper @ dweaver. But the SM3 doesn't stay there consistently, meaning it the actually recording had lighter bass, you will get lighter bass. If it's like rap with constant subwoofer bass, that's what you get. These IEMs bend to the music rather than making the music bend to them. These are nowhere the size of the the TF10, so fit issues shouldn't be a problem. It's designed to sit and fit like in-ear monitors you see professional musicians wear on stage. You just have to find the right tip for the perfect seal and sound you're seeking. You need a fairly deep seal. These aren't meant to be worn with a shallow seal at all. The double flanges that come with the SM3 will be perfect if you are someone like me who can't really deal with trip flanges. I have, however, found that the large Monster triple flange works for me. And the Ety large gray triple worked too, but I have sliced the tips off to make them a double flange now. One major reason for doing this is because the Ety tip was so narrow. The IEMs require a wide tip hole at the end of the tip for optimal soundstage and sound spectrum performance.
Mine shipped the next day too, though this was around a month ago. Also, my tracking number worked too, though the Colissimo website was not providing constant updates like FedEx/UPS tracking. I was able to track from the Colissimo international website as well as USPS. The USPS website however, gave me all the tracking information as soon as it arrived in the U.S. It let me know when it went through customs/left, when it arrived at my local post office, when it was out for delivery, and when it was delivered. I recommend trying to paste the tracking number onto the USPS tracking box on USPS' website.
Enough is enough. Although triple flange is good, I have decided to get custom earmold on my SM3, and delay the plan of getting custom iem till at least one or two years later. Now it's just down to finding a good time to make a trip to the audiology center.
