I actually think it would be a good pairing, being that the etymotics is a very micro detail IEM, and 2.05 is warmer and in my opinion Bassier than 2.00. Compare the 2 and pick a winner!
Interesting you say 2.0.5 is bassier than 2.0.0, I find 2.0.0 bassier than 2.0.5 and 2.0.5 lacking lower bass altogether. I used both types of phones, warmer and bright but no matter which one the results yielded were the same. I would go with the last suggestion.
I'm coming back again,
This question is addressed to every body :
don't you think that it is time to record the Sound Quality from headphone exactly how it sounds ?
i mean record the sound exactly as it sounds with for exemple Westone 4R, Roxanne, V-MODA XS etc.... when the user put theses headphone on his ear.
I don't know how it is possible, but, if it does not exist yet, it would be useful to work on.
oh yep someone can say that, even if the sound is recorded, the headphone you use to listen will transform the SQ. yes but that need to be work on also via a neutral software Or the headphone to use to listen could be indicated etc....
it is just an idea .....
sam
That was suggested earlier to @jamato8 and he is ok with that, just look at the post from the impression thread and see if you can provide the info as he expects it. We really only need one location and the impression thread would make more sense as you provide your impressions and we should know what the gear you used was when you did.
