DX320 ROHM dac chips, Android 11, AMP11MK2s. *******NEW FW: 2.07*******
Oct 1, 2023 at 2:04 AM Post #10,036 of 10,616
Ok I have the Ibasso dx320 and amp 12 that I love!
I wanted to try the amp 14, well I have it and it’s blooded base and very, very, very hot. The soundstage is the same as the other two, to my ears,
Am I missing something????
I don’t get!?
Oct 1, 2023 at 4:23 AM Post #10,037 of 10,616
Not me, but why use it with the ibasso? the Go Pod is a wireless device for iems right?... I use my mobile on the go with LDAC phones
It's easy to imagine that in certain circumstances the wireless option is convenient... The wireless option with iPhone is limited to AAC, clearly inferior to LDAC or APTX.
Does it pop only with the Go Pod or any wireless device? you can rule out the player or app if its only happening to the Go Pods or maybe LDAC pops what about Aptx?
Have you tried to reboot it?
The described situation only happens with the GoPod + Mango Player (Android) and remains after reboot.
Oct 1, 2023 at 6:52 AM Post #10,038 of 10,616
I don’t get!?
No you aren't.
Depending on your music choice and IEM/headphones, you may not be driving them well with the amp14. The DX320 gets warm with the nutube, but not hot.
Oct 1, 2023 at 1:38 PM Post #10,039 of 10,616
Ah I see its iphone, I stopped using the iphone for wireless music after they got rid of the headphone jack and proprietary monkey business. But the $10 dongle attached to wired is not bad with a good app to play Flac.
It was a mixed bag with the iphone and wireless, I was trying so many wireless headphones with the iphone and Android. I found out some headphones sounded different depending on what device/codec supported, some sounded better on iphone but would sound terrible on android and vice/versus. I get your point.
If it is happening with Mango you could try to use another player for wireless, could be a bug. USB Audio Player, Hiby Player, Sony Music Center, Musicolet, PowerAmp, Neutron to name a few. Also what firmware are you on? Did you recently update and if so factory reset after ( i know its weird but fixed a lot of issues i had in the beginning)?
Oct 3, 2023 at 6:19 AM Post #10,042 of 10,616
Hi All,
How to hide Apps on the Android 11 of DX320 ?!
I would like to hide some Apps that I just do not use (without uninstalling them) ?
Thanks in advance for any help.
The idea is to have them removed (hide) from any pane...
Try this. After all it is using the same OS as a phone would (though some things have been removed that make no sense to have with it not being a phone).
Oct 4, 2023 at 7:07 AM Post #10,043 of 10,616
Thanks.
The problem is with Android 11... With Android 12 there is the option of hiding which is different from disabling (some apps do need to keep running in the background).
Oct 4, 2023 at 12:16 PM Post #10,045 of 10,616
Touch the app icon that you want to remove until you see "My Apps" option. Drag the icon over "My Apps" and you will see two options at the top of the screen "Remove" and "Uninstall". "Remove" does just that, deletes the icon without uninstalling the app. If you want to access the app later, swipe up from the bottom of the screen and you will see all installed apps.
I have used this method to remove every app from view and just have my essential apps on my dock.
Oct 4, 2023 at 1:08 PM Post #10,046 of 10,616
On my DX320 (latest firmware) when I touch the App (for a short period of time) the only option I get is the Uninstall (or to move to different location-pages)
Oct 4, 2023 at 1:34 PM Post #10,047 of 10,616
I am also on the latest firmware. I should be more specific - when you hold an app icon and move it, you get different options at the top of the screen. I usually see both Remove (upper left) and Uninstall (upper right). In some cases I only see "Remove" but I have not seen an option only for "Uninstall". This may be app specific but I have only a limited number of apps I installed beyond default - Apple Music, Netflix, Speedtest, Fiio Control, and PowerAmp EQ. It's possible I uninstalled some default apps when I initially setup my DX320 but can't remember.
Oct 4, 2023 at 3:17 PM Post #10,048 of 10,616
It's been a few years since I've had a droid phone, but the ways i've previously accomplished what you are describing is by downloading and installing a different launcher. I have that applied to my dx160, so the only visible apps are the music apps I use.
Oct 4, 2023 at 3:17 PM Post #10,049 of 10,616
You need to change your home screen mode. Hold your finger on the screen, select Home settings - turn off The main screen.
