The black case also goes well with the blue of the DX300 also.DX320 Black + AMP12 (Black) was my choice and I'm very pleased with this combination (aesthetically & sonically)
I think it is pretty common for any DAP ?I hope I'm asking this in the right place... is there an app or shortcut that makes it easy to go into dac/amp mode so I can use with my phone or laptop? It's a clumsy 4-5 steps to get there today.
You may be right. It would be amazing if it were in the swipe down control center as a simple switch.I think it is pretty common for any DAP ?
On your home screen, swipe right, and there is a button to put it into DAC mode.I hope I'm asking this in the right place... is there an app or shortcut that makes it easy to go into dac/amp mode so I can use with my phone or laptop? It's a clumsy 4-5 steps to get there today.
You're not missing anything, and yes, the DX will take care of the bypassing of android OS limits. It will play as high of a resolution as you can feed it (pretty much).Am I losing anything by just using Apple Music for Android on the dx320? Everything is set to "Hi-Res Lossless" in the app. Does the dx320 take care of bypassing any sort of layers in AndroidOS so it sounds as good as it can?
When booting it up, do you see the iBasso logo before it tries to boot to either Mango OS or android (depending on what you have it set to do), or does it remain completely blank (but with backlight) the entire time. Have you tried rebooting it? You could try and hold the power button for (I think) 15 seconds or so to reset it. Also, you COULD try re-flashing the FW just to make sure it isn't a corrupted FW. It sounds a bit like your screen is dead, but it is probably best if you try a few things first before sending it back for warranty (if you are so inclined).Hi all,
The screen on my DX320 is not turning on. The backlight comes on and I can access teh harddrive through my PC but the screen is blank.
Has anyone exprienced this or know of any solutions? Luckily it is still within warrnaty.
Nothing appears on the screen. I have tried everything apart from reflashing firmware, not sure how that is done.When booting it up, do you see the iBasso logo before it tries to boot to either Mango OS or android (depending on what you have it set to do), or does it remain completely blank (but with backlight) the entire time. Have you tried rebooting it? You could try and hold the power button for (I think) 15 seconds or so to reset it. Also, you COULD try re-flashing the FW just to make sure it isn't a corrupted FW. It sounds a bit like your screen is dead, but it is probably best if you try a few things first before sending it back for warranty (if you are so inclined).![]()
First page of this thread has the tool to use on your PC and the FW and the instructions...Nothing appears on the screen. I have tried everything apart from reflashing firmware, not sure how that is done.
THank you!First page of this thread has the tool to use on your PC and the FW and the instructions...It is really quite easy.
You're welcome! I hope you get it sorted out?!THank you!
I can also confirm it does, I use Apple Music on dx320 as well!Am I losing anything by just using Apple Music for Android on the dx320? Everything is set to "Hi-Res Lossless" in the app. Does the dx320 take care of bypassing any sort of layers in AndroidOS so it sounds as good as it can?
I recently had a similar experience but using a modded amp12exn-s amp. When the device warmed up (especially when battery was charging) the screen went and stayed blank. I'm guessing it was some protection, but one of those gaming phone coolers solved the issue. Sounds like your situation might perhaps be a more extreme case of what I had (for me swapping out to a stock module or just letting the phone cool down solved the issue)Hi all,
