DX320 ROHM dac chips, Android 11, AMP11MK2s. *******NEW FW: 2.07*******
Sep 21, 2023 at 4:13 PM Post #10,006 of 10,618
3. The whole update will take about 10 minutes. Reboot the DX320 after update completed. You can also choose to do a factory reset at this time to clear any artifacts from the previous firmware.
Is it mandatory to do a factory reset and doing so I imagine it will delete all my music files located at the internal, right ?
Thanks.
Sep 21, 2023 at 4:22 PM Post #10,008 of 10,618
Thanks.
No you don't have to but if there is any issues, then a reset normally fixes it but most of the time I don't do one.
Sep 21, 2023 at 4:24 PM Post #10,009 of 10,618
Hi All,
Is it possible to use the iBasso Burn-In cable on a different DAP brand using an adapter (2.5 - 4.4) ?
Thanks.
Sure, no issue with doing that. Just like using any plug from a headphone or IEM.
Sep 21, 2023 at 6:46 PM Post #10,013 of 10,618
EXN-s with OP-AMP ADA is different perfomance level than stock amp11mk2 or 13/14/12 stock. i wonder however how big is the difference between 320X w EXN-S and MAX. Tonally i prefer 320x with exns for iems.
Sep 22, 2023 at 6:32 AM Post #10,019 of 10,618
Sep 26, 2023 at 4:53 PM Post #10,020 of 10,618
Agreed!
Amp 12 drives them and synergizes with them to a heavenly level (IMHO). I am just excited that I will (soon) have that option to drive them with a tube amp card also (from the DX as portable).....
HMMM! I wonder what case they will put in with this amp card?!
I’m sure by now you figured out that the amp14 will not power your 600 ohm iem well
