Jefecesti
I used to do this by pairing the phone and dac/amp. In theory, the same should be possible with 320.Have anyone paired the 320 and phone by usb or bluetooth and had phonecalls with headphones?
And I’ve never used any cables with mic.I used to do this by pairing the phone and dac/amp. In theory, the same should be possible with 320.
I was and almost bought it, but I got good deal on basic one with amp13.Anyone else is excited to get an edition X ? I wonder
Are you getting one? They look insane. I wouldn't want to use a case with one.Anyone else is excited to get an edition X ? I wonder
I do want it, but my pocket may not agree :/Are you getting one? They look insane. I wouldn't want to use a case with one.
The cost vs the orig were too much for me. And the sound presumably won't Be upgraded that much.I was and almost bought it, but I got good deal on basic one with amp13.
They look insane, but one won't enjoy it due to the needed pocket.I do want it, but my pocket may not agree :/
More like just being unique , because as Paul has mentioned, only the chassis changed. However, I have unique amp modules myself…..so the more reason to get it lol!The cost vs the orig were too much for me. And the sound presumably won't Be upgraded that much.
Basically the money rules.More like just being unique , because as Paul has mentioned, only the chassis changed. However, I have unique amp modules myself…..so the more reason to get it lol!
I have never used it this way, but ironically and recently I have been trying to revisit reverse BT which works with my phone just fine but has never worked with my Samsung smart TV (nor am I the only one that has had this issue in the past). What's funny about this (more like ironic) is that I just assumed it was an issue on the TV. Well, I got a little Shanling M0 for my wife, and was playing around with it and it paired with my TV (in reverse BT) first try and with no difficulties.Have anyone paired the 320 and phone by usb or bluetooth and had phonecalls with headphones?
The whole and complete reason I went for a DAP solution, is to separate my music off my phone.The DX can do everything my phone can do (but much better) except make phone calls, and why would I pair it to make a phone call?! Just some thoughts nonetheless.
Same here, though I don't even use the DX for tagging. I use my PC for all of that, then download to the DX... It is STRICTLY a playback device for me.The whole and complete reason I went for a DAP solution, is to separate my music off my phone.
DX320 has DuckDuckGo browser (for reading or downloading music/album art) and 3 music apps. That’s it. No notifications at all. It’s a music listening experience only. If I pick up the phone to check email or anything…. the music keeps on playing.
I believe most charging issues from new player is because of the need to update to latest firmware.Good evening everyone. I can't turn on my DX320. Initially it turned on but it didn't... I put it on the Asus 30w charger, which I've been using since I bought it, it appeared battery 90%, Any idea what I can do... Now it doesn't want to connect at all.
I have an issue with it not having sound, and found out that it was my 4.4bal plug. I simply had to twist it for amp to be activated. Either my plug is not designed good or I have to clean it.i have a question about dx320. after I turn off the dx320 and don't use it for a while(3-5 hrs), when I turn on the dx320 again, there is no sound for the first 30-60 seconds. only a bit later the sound comes out, is it normal? sometimes comes out only from the right earpiece, and sometimes only from the left. but after a minute it's all back to normal. It's not the problem with my earphones because they play normal with other daps.
Yes I tested the other players only with pausing DSD. On Neutron it made a pop 2sec after pausing music, but only with the "all to DSD" settings. With a native DSD, I didn't get a pop.@Maxx134 today I just experienced the DSD switching toward PCM from USB-PP, and omg…it was so loud that it popped my Soul somewhere … luckily I wasn’t on my IER-Z1R, but rather the 800s, so it was t deafening. But this is something alarming that should be brought toward Ibasso attentions @Paul - iBasso
I get it only with Neutron when changing settings making all to DSD (except native DSD file);If you decide to try this setting, be very careful not to use any IEMs, as I can imagine a dangerous pop 2 second after pausing the converted DSD file, which was dependant on volume.I use DSD and PCM and never get this. What did you do or what led up to this?
