Short answer, yes....I've just saw the neutron's website ( http://neutronmp.com/ ) and there is a name of DX200.
Has neutron already fully supported DX200?
DX200=Affordable High End Audio. Dual ES9028Pro dacs. AMP1, AMP3, AMP5, AMP7 & AMP8 ***Firmware support now up for AMP9***
- Thread starter Paul - iBasso
- Tags
- at8ie ibasso ibasso dx200
- Oct 14, 2013
It has been there and listed for a while....but I think Ibasso will be doing something to their firmware ?I've just saw the neutron's website ( http://neutronmp.com/ ) and there is a name of DX200.
mrmoto050
Yep, I use it all the time.I've just saw the neutron's website ( http://neutronmp.com/ ) and there is a name of DX200.
wirefriend
- Jan 10, 2014
Neutron plays bit-perfect if you switch DX200 to the lastest alternative firmware by Lurker (DX200FirmwareV2.5.141-L1) here:
https://github.com/Lurker00/DX200-firmware/releases
This firmware includes root and Google Play as well.
Paul - iBasso
Sponsor: iBasso
We have been working in collaboration with Neutron for some time now. We have worked toward having bit perfect in all formats with the DX200 so that everything works seamlessly.
Stay updated on iBasso at their sponsor profile on Head-Fi.
Dobrescu George
Reviewer: AudiophileHeaven
Woah, super great job!
I guess it is time to buy a copy of neutron for myself then
I have like a feeling that even then I might go back to using the stock app, but having the option of having fully optimized Neutron is so nice
The result has been fantastic. Neutron has worked really well with the DX200 since the addition of support for the DX200.We have been working in collaboration with Neutron for some time now. We have worked toward having bit perfect in all formats with the DX200 so that everything works seamlessly.
Signal2Noise
Now if only Neutron can overhaul their GUI to make it more attractive and intuitive. Looks like outdated crap on a state-of-the-art device like the DX200
I know this hasn’t anything to do with the DX200, but thought it only fair to put this on here. Some of you may know or know of @moedawg140 , he has been taken into hospital with a serious bleed on the brain and is in need of urgent surgery. Here is the link to the fundraiser/
https://www.gofundme.com/maurice-and-suzzettes-medical-fund
The link is also on the front page of head-fi.
The target amount hasn’t far to go to get him the surgery he needs. Thanks
ctaxxxx
For those using AMP3's Line Out to a BAL headphone amp, where did you buy your cable? All I can find is one seller. Not a lot of options...
meomap
I think ALO should have one.
I will order mine from DHC but expensive. I bought some products from these two vendors.
You can contact with any famous brand like effect, dhc, toxic, norne, plussound where you can contact in thread of headfi cable forum and tell the spec you want to customize.
Likeimthere
And also Tidal support... and MQA... that'll make things perfect...
Tidal might be possible but Since MQA is not supported for HW decoded native by default DX200 so I think this is too big dream to think about.
Total: 7 (members: 0, guests: 7)
