DX200=Affordable High End Audio. Dual ES9028Pro dacs. AMP1, AMP3, AMP5, AMP7 & AMP8 ***Firmware support now up for AMP9***
Discussion in 'Portable Source Gear' started by paul - ibasso, Dec 17, 2015.
622 623 624 625 626 627 628 629 630 631
633 634 635 636 637 638 639 640 641 642
  1. icefalkon
  2. Glasha
  3. musicday
    Hi Paul, again :)
    I understand that you cannot disclose the price of the copper and titanium versions now, but for sure you must know when you can tell us. Give us a day, we are waiting for this. Thank you, Musicday.
    Glasha likes this.
  4. Glasha
    2072
  5. musicday
    PO BOX :)
  6. alota
    today i was listening some albuns with tidal offine.
    the reproductin paused alone 4 times.
    does this happens to someone?
  7. koven Contributor
    Anyone have issue accessing the internal storage thru Windows 10? I see the DX200 mounted but folder is empty and won't let me drag anything in.
  8. Womaz
    I have read this whole thread over the last few weeks and I seem to recall that this may only happen if you are storing the music on an extranal SD card. I have tried to search this thread but seem unable to locate the exact posts
    alota likes this.
  9. Dobrescu George
    Try a reset, I don't have this problem, works flawlessly with winodws 10 latest update applied.
  10. Signal2Noise
    Due to lack of information I'll have to ask: did you enable File Transfer option on the DX200 once connected to computer?
    mrmoto050 and Dobrescu George like this.
  11. minsan
    This has happened to me multiple times and still does occasionally. Mango or 3rd party player. My music are on the SD card.
    @Paul - iBasso and team are aware of this issue IIRC.
    alota likes this.
  12. cbeaumont001
    In the newest version of Neutron released a couple of days ago on Play store there is a setting under "generic driver" called hi res speaker. When selected, it changes the bits entry at the top of the audio hardware screen from "32 (out: 16)" to "32 (out: 8.24)". Does anyone know what this means or if it actually has any affect on the output going to the headphone amp section?
  13. tuckers
    In Mango OS, I only get the SD card, but in Android, I get both drives.
  14. drmacman
    I'm wondering about that. Might be 16bit or 32bit-float I think...
    Also when I play DSF, there is no dialog showing " USB Device connected" you can see in Mango player, but my memory is correct, To connect to XMOS is needed for playing DSD directly.
    Are DSD files really played in bit perfect (not convert to PCM) in default or should I configure something?
  15. Paul - iBasso
    You are correct. We will have this fixed in our upcoming FW.
    iBasso Stay updated on iBasso at their sponsor page on Head-Fi.
    http://www.ibasso.com/
    Glasha likes this.
