a brief PCM refresher is key first. Hope this helped. Please don't tell me you already knew all this and I just : )
No, this was immensely helpful, many thanks! And thanks to @Whitigir too
However, it does leave me with a few questions.
1) I believe Whitigir said that CD's can be converted into DSD?
My understanding from what you and he wrote is that DSD of any type has a far higher sample rate (and hence quantity of information, even at 1 bit) than a 16/44 CD (or FLAC file).
So how can a CD be converted into a DSD file of a higher quality? Or is this also just a form of 'fill in the blanks' upscaling?
2) From which sources can one obtain music in DSD format without any upscaling?
3) I'm still a bit confused about the difference/relationship between DSF and DSD?
Perhaps it would help me if you could describe using practical examples involving playback on a DAP? As in, what format do I ultimately need it to be in so that I can just stick the file on a micro-SD card (or external HDD) and play it on the DX200?
Because that's ultimately my goal here lol
