parabellum777
2.10.215-L0
Official release notes:
1. Folder Play function has been added. It can be found under Settings/Play mode.(Android OS)
2. Improvement to the UI response.(Android OS)
3. Rectified the bug that AAC and WMA can't be played via Bluetooth.(Android OS)
Nothing new from me.
Thank you so much for your work, Lurker. That was really fast from your side. I have updated the firmware and it is working perfectly.
However, I´m still having ONE small sound cut with EVERY song I play from Tidal, both online and offline modes. The sound cut happens two or three seconds after the start of the song, for every song. It´s really annoying, and I don´t really know if the problem is caused by the DAP or by the Tidal Android app. I know it is not an issue caused by Lurker´s version, since It also happens with the official firmware version.
Is anyone else experimenting this issue?
