davidmolliere
Amp8 > andros vol needed = 10? Lol
Yeah I am afraid my Phantom will be the same... iBasso needs to add "Low gain" to the firmware
I've tried to play test files from here using UAPP playing via Android, with variable rate. No problem!22.05 kHz
I'm sure I don't, because I don't understand what are you talking aboutany software that have the controls over Latency and buffering
But Neutron has some similarly named settings. I don't understand what good for are they either.
@Lurker0 do you have any software that have the controls over Latency and buffering that works with DX200 ? Thanks
I believe there are some settings inside USB Audio Player Pro also.Thank you, I will check that out.
Which is there for ages
Yeah, this might be useful with more powerful ampsYeah sorry, I meant lower gain like High - Normal - Low and there are only two positions I just meant one position lower good point
