Mackgear
- Nov 5, 2016
Please tell us the detailed specifications of Dx200!
it's on the 1st page.
Do you really think it is enough?
It is really lacking information from the consumer's point of view.
Yes I second what is said above, if you want a beta tester, conveniently located in China and that can compare it to the Lotoo Paw Gold and Sony WM1Z, as well as the Mojo, don't hesitate to send me a test unit
There are a couple of regular members always in this thread who have gone mysteriously quite the last few weeks. Uncle H20 has (suspicions / assumptions) they may have test units.
But keep in mind it's just a H20Fidelity crazy observation.
The ES9038 has not been released. The specifications have been but not the chip. The ES9028 is what we are using and it does an excellent job.
^ No, they are all 8 channel, the ES9028 is essentially the same dac architecture as the older ES9018, both are 8 channel, both same dynamic range and THD+N specs, but the newer model has features for easier implementation and flexibility, so it should still sound better than the previous model in any given setup even though they have the same technical spec.
The ES9038 is the flagship, still 8 channel, still very samey architecture, but with better DNR and THD+N specs. Ayre and Oppo have used this chip in their upcoming products.
Stay updated on iBasso at their sponsor profile on Head-Fi.
