Lurker0
Windows Device Manager, when you double click on a device in the list.Where do you find VID/PID of this unknown device? What is “hardware ids” at the details tab?
Ok. Here is my problem. Once I listened DX200 Gold plated Copper yesterday. Now I feel that all musics from other portable sources become so dull and not lively anymore.
Any advise?
1. Buy the DX200 Au/Cu
2. Keep the your absolute favorite headphones to use with #1
3. Consider this your end game
4. Give me the rest of your audio gear
1. Steal the DX200 Au/Cu
can i confirm the line out :
1. amp1 = single ended
2. amp3 = balanced
and the amp3 balanced line out should not feed the rca of an amp?
For line out you are correct on 1 and 2. You never want to feed a balanced output to a single ended. An RCA of an amp would be single ended. You will burn out the output chip if you hook up balanced to singled ended as you are grounding the negative output of the balanced section.can i confirm the line out :
2. amp3 = balanced
Stay updated on iBasso at their sponsor profile on Head-Fi.
The end of the month. It is well worth the wait! all for Enjoying the Music!Has there been any ETA for the amp 4 release yet? I’m getting anxious!
I noticed the track on the screen, and I much appreciate your choice!The amp4 is a great companion and drives the XC perfectly.
+1I noticed the track on the screen, and I much appreciate your choice!
Glad you're up and running again. +1 on the artist/album frustration. Not easy in Android mode, and album tracks get put out of order. In Mango mode works fine until powered off, when tracks get rearranged alphabetically on restart. Hopefully these bugs will be fixed in next FW. Personally, I also like the inclusion of "album artist" rather than just "artist" when searching via artist. Maybe I am just too antiquated, still listening to albums rather than tracks or playlists....!
