- May 7, 2017
Isn't DX200 like about half of the price of 1Z?
Yes, I just bought DX200 for $899 at B&H and amp3/amp5 both $199 each at Penon Audio. Way cheaper than WM1Z and SP1000.
I just received the Amp5 and cannot believe the improvements in soundstage, dynamics and timbre I hear. It turns my CA Orion into an Andromeda!!! The improved battery run-time will be a welcome bonus.Get AMP3 for 2.5mm Balanced, and AMP5 for best SE experience.
Yes, I was expecting an improvement but not one of this magnitude.People need to hear it to believe how awesome it is
Here is a word document that comes with the Rockchip Factory Tool that will answer all of your questions, I think.Hi guys
I am trying to work out how to get Lurker firmware on to my 200 so I can get google play on there and therefore a few other apps
I have read and re read the instructions but I am not good with all of this and would love some clarification.
I have downloaded the zip file DX200FirmwareV2.8.198-L0-rkflashtool (2) to my PC. I have extracted this on to my PC so the fiLe is ready to be out on to my DX200.
Then I look at how to install this and I get totally confused........Do i have to install a batch tool to my 200 also. I have looked at the guide and it talks abiut restarting my computer. Not sure why I have to restart my computer. Are the tools put on to my Computer or the 200?
Is there anywhere I can find an easy to follow guide on how to get the Lurker firmware on.
I really need some help with this as been battling with it for 3 days now
Yes I attached it. Hmmm they must block word documents. Here is the same document but in the body of my post.....Did you attach it? Nothing there
1) Click Here for the latest firmware. Yes. You should have a .img file to upload.I really appreciate the time you have taken to help me.
I have those instructions now, but to me they are still unclear.
Point 1 ....which latest firmware, the one I have mentioned above. Do I have to extract this to my PC first as its a zip file.
7 If I have this on my desktop will this be easier?
8 I have windows 10 is this 64 bit?
9 Why do I have to restart my lap top? ........surely this is going on to my 200??
10 What is the batch tool I am supposed to be launching?
My apologies I am not dumb by any means but I am 54 and all of this PC talk I dont understand at all.
I was determined to get this sorted as the 200 may have to go for a proper android DAP if I cant do this.....but part of me thinks this is way over my head.
When i first got the 200 I manged to get the tidal app on by taking some guidance but this was very straighforward
7) It doesn't matter. Just remember where it is.
8) It will work with 64bit Windows 10.
9) Because you installed USB drivers for DX200. Windows needs to know that your DX200 is there and have the correct instructions to talk with the DX200. It's best to reboot windows after a driver install.
10) Click Here to download the tool. You will need to unzip it to use it.
Get a new USB C cable.Thanks so much for the help.
I think I am ready to attempt this, but not sure I have an .img file. I have unzipped the folder and it says it is a disc image file??
I may have difficulties with doing this too as for some reason my 200 does not always connect to my lap top....sometimes i have to plug in the USB cable about 10 or 20 times
Your welcome. Glad to be of help.Thank you so much. You have managed to guide me through this successfully. I could not have done this without your help.
So I have a google account now and I have downloaded Qobuz, Tidal, Audible and Iplayer to the 200.
I am hoping that I wont have to ever do this again.
