That phone is using dual mobile 2 channel dacs (2x ES9028C2M), the DX200 is using a single desktop dac (ES9028PRO), which has 8 dac channels. If theoretical performance spec sheets are your thing then the single desktop dac still outperforms the dual mobile dacs...
I actually make a point to go for dap's with single dac myself, it is an indicator that the company isn't concerned with marketing and more concerned with actual performance (not in DX200's case, I'd wager they just couldn't fit two dacs in...).
I haven't seen any evidence that a dual dac setup (in the constraints of a dap) performs better than a single dac, I have seen the opposite though. When your running on 3.7v battery power, the limiting factor in performance of all daps is the power supply and it's regulation, the more chips and power you draw, the more strain is on the power supply, the worse the regulation gets, the higher the internal resistance becomes, and the sound quality is affected.
In DX90, using a better quality battery increased sound quality, it underlined the fact that the power supply resistance was a limiting factor in it's design, it may have had better sound quality with a single dac rather than it's dual mobile ess dacs.
There are certain companies out there that make a point to use a single dac in their dap as they choose pure engineering above marketing. I would choose QA360LE, Aune M2S, HA-P90SD, Pono, Esther M1, QP1R, etc, over any AK and over DX80, N6 etc.
You have to remember most dac chips only costs $5, add in another couple dollars for it's opamp lpf, point being it's not difficult to implement dual dacs for these dap companies, they do it for marketing, with no thought on performance. AK cripple the amp section in ak100ii/ak300 so that the ak120ii/ak320 sounds better and people think it's the dual dacs their hearing... To top it off they don't even implement a line out on their daps so people can't directly compare dual dac vs single dac... No thanks, I will stick to daps engineered to perform, not look pretty on paper.
AK's business model is obnoxious, stripping away quality of the lower models, where is the native DSD? Only ak240/ak380 have it, Why? There are $200 daps that do native dsd, yet people still don't understand how obnoxious AK's business model is. The stripping of features would be ok if it was just that, but it isn't, the PCM playback is also affected by this, in ak240/ak380 the xmos chip that handles the native dsd is also acting as a decoupler from the cpu for sending i2s to the dac, which increases sound quality of even PCM playback, which is why people say ak240 sounds better "more analog" than ak120ii, despite them both sharing the same dac and amp section. Thus none of AK's products are worth owning in my opinion, they are just a mix of mostly crippled and otherwise overpriced offerings... If you want the best sound quality look for a dap with native dsd, as it also affects PCM playback.
That's me. As individuals we all have different priorities.
