I'm enjoying this new firmwares sound.
DX200/ Andromeda with CB13 cable
Could you describe a differance between Ref8 and CB13 with Andromeda?
But cables don't make any difference*...
*humour
Why not just buy a USB hub, or a USB wall charger (with quick charge) for the DX200?Does anyone know of a connector USB C that is a dual/Y that allows a SSD to be used and the DX200 charged. So it would be a standard USB with 2 USB C.
I want to get an SSD drive and use it on the USB C input of the DX200 but also supply a charge to the DX200 at the same time. So one split cable and on the go I sometimes use a flat nice portable Anker battery.Why not just buy a USB hub, or a USB wall charger (with quick charge) for the DX200?
For variety. I have a few 256gb, 5 200, about 20 cards in all. The single slot with internal memory is fine and works great. I was looking at a 500gb SSD.Wait... You mean an external SSD drive for storing songs and other types of media right? Are you trying to access those songs through the SSD because 1 microSD card does not have enough space? Why not just buy another microSD card and switch it out so you don't need a USB split cable?
