ropie
- Dec 30, 2013
Yes.
I tell you the truth But you can understand that there is a difference between "1 vs 4" and "4 vs 8", especially because 8 cores are not required, and are mostly sleep, when 1 core alone is overloaded. Then it influences the power supply, that is common for all the parts.
But some people believe that a few lines in a text file (yes: just useless for any other means text lines!) inside firmware make the sound better I just tell you what the change was done, and how it may influence.
Thanks for the reply,
I know you are not responsible for the change, but you are, as far as I know, one of the few people (besides the people from Ibssso) that can (or might be able) to explain what causes the change in sound.
I am just curious what can explain the difference in sound signature (which is definately not placebo)
I meant; in the previous firmware there should be a significant change in sound once switching the screen off or on. The unit would go from 8 cores to one or reverse, but I never noticed a difference in sound with the screen on or off.
Still very happy with the new sound though, and also yout work, so maybe stop trying explaining and just sit back and enjoy.
.......unless of course Ibasso would care to enlighten?
Paul?
