KK-android
- May 29, 2013
Yes.
It depends on your definition of "quality", your hearing and taste.
You see, even with bit perfect playback, there are several factors that affect the soung signature. Some people hear the difference e.g. between Mango alone and Mango Android, or between different firmware versions, someone does not hear. In all these cases the playback is bit perfect. The difference is caused, most probably, by CPU load and similar factors, because DX200 has one and the same power source (battery) for all the parts.
The sound signature with USB Audio should be similar to using DX200 as USB DAC with an external source, because XMOS chip runs exactly the same way.
Thanks for reply.
all right now.
