- Oct 14, 2013
DX200 with iPad charger is ok. I did it all the time
Mango is pure music operating only. Best is to hold power button until it says, good bye, then take out the MicroSD, put in windows, drag n dropHi comrades, why reader isn't working in Mango? How come it's not working?
But since the Reader option is there, it should be working, I think.Mango is pure music operating only. Best is to hold power button until it says, good bye, then take out the MicroSD, put in windows, drag n drop
Coming from a Fiio X7ii, i find the stock leather case of the DX200 rather big, cubersome. Is there any silicone case option? Would be much better in my opinion
I tried to do the same for the DX150 but I could not locate where the clip is. Is the clip located in the same area as the volume dial or the other end? May I also ask how do you unclip the clip on the side?Once you have removed then gently unclip the back there is a clip on one side to hold but it's easily distinguishable as obviously it won't lift and be careful as both battery and antenna are attached to the back, but it is honestly not as daunting as it sounds then gently with a flat ended screw driver prize off the battery from the back plate as it is stuck with double sided tape.
You will end up in this position.
I can't comment on the DX150 but if its built the same then the clip is I think if I remember rightly volume wheel side and near it, but the clip is just an L shape and as far as I could tell is only catching the lip of the frame,, no recess for it.. But ss I said no experience of the dx 150I tried to do the same for the DX150 but I could not locate where the clip is. Is the clip located in the same area as the volume dial or the other end? May I also ask how do you unclip the clip on the side?
Yea for sure. I am using it on the DX220 now.I see someone got lucky! You do realise I will be not off this thread now in anticipation lol
Tested out of my DX220 for both AMP8 vs AMP9, quick impression will be the AMP9 has a buttery smooth sound with textured bass, focused midrange and smooth treble. The soundstage gives an intimate feeling. Cheers!Well obviously the big question is V amp8.... I'm biting my nails... My 200 is up for sale but this little beauty could easily change that.
thanks looks very promising then... Looking forward to more detailed comparison once you have summed it up, cheers.Tested out of my DX220 for both AMP8 vs AMP9, quick impression will be the AMP9 has a buttery smooth sound with textured bass, focused midrange and smooth treble. The soundstage gives an intimate feeling. Cheers!
