guys, why bother with this format, isn't it a gimmick? one can hardly hear any sound difference, also it's oversized and making devices discharge faster! no?DSD 512
DX200=Affordable High End Audio. Dual ES9028Pro dacs. AMP1, AMP3, AMP5, AMP7 & AMP8 ***Firmware support now up for AMP9***
- Thread starter Paul - iBasso
- Tags
- at8ie ibasso ibasso dx200
Mario Samek
Hello, you think of this can successfully solve my problem of sound? Thank you.
AMTRA: https://www.xivero.com/amtra/
ctaxxxx
I was able to hear a subtle difference with my Sony MDR-Z1R (blacker background mainly), but I didn't find it worth the storage and battery drain. You can always up-sample a FLAC song for free and hear for yourself. Use a song you are very familiar with.guys, why bother with this format, isn't it a gimmick? one can hardly hear any sound difference, also it's oversized and making devices discharge faster! no?
Paul - iBasso recommends to leave the DX200 plugged in the charger, while fully charged, when listening to DSD512. The high battery drain affects all portable devices. Don't bother with DSD512 when you're on the go.
ranjitotski
- Dec 19, 2015
Anyone using lurker mod here for oreo? What other compatible modules that can be installed in magisk except for the usb audio? Thanks!
ranjitotski
- Dec 19, 2015
I just tried my se846 with brown knowles dampers plus nawaza cable and i was suppah duppah blown away!
Mario Samek
Thank you to all, I now back to old stable official 6.01 firmware and download only official updates. no again experiments! no google play store and playback only purchased and downloaded albums in qobuz, with amtra and DSD128 rebuild albums in xivero programs... not again fail experiments with my device and only playback standard with or without mango or hear music plug-in USB Cable to DAC mode for imac... Bye all!
ranjitotski
- Dec 19, 2015
Which is better amp 8 3.5 pro or amp 8? What’s the diff? Thanks!
Paul - iBasso
Sponsor: iBasso
The only difference is the socket.Which is better amp 8 3.5 pro or amp 8? What’s the diff? Thanks!
Stay updated on iBasso at their sponsor profile on Head-Fi.
ranjitotski
- Dec 19, 2015
Thanks sir @Paul - iBasso! I think i need to go with the amp 8 4.4mm!
SuperelvinSH
hmmm ok, it's good to know!Neutron was the music app I had been using since Samsung Galaxy Note 2 until Note 3 (then I became an Apple fan)
It was really glad seeing it support the DX200 with an exclusive driver that makes the native DSD mode work.
My Dx204S don't charge anymore
Contacted Paul but the real question is, how can I survive without it if I have to send it back?
headwhacker
- Sep 4, 2013
Buy a bakcup DX200. Perhaps look for a good deal from FS section.My Dx204S don't charge anymore
- May 7, 2017
I had my DX200TI back to ibasso for repair in a couple months ago and had to listen to my DP-X1 for a back up. It was ok!
nazrin313
I had a problem with the battery draining really fast after 50%, turned out there was an issue with the battery. Emailed Ibasso about the issue and they sent over a replacement battery no questions asked. Installed battery myself (easy) and now working perfectly. Great support Ibasso!!My Dx204S don't charge anymore
I have gone to the enemy just bought a used zx300 for the time of repairBuy a bakcup DX200. Perhaps look for a good deal from FS section.
Total: 8 (members: 0, guests: 8)
