nazrin313
Iphone user?It is so complicated. That is why I just wait a stable official FW update available.
Iphone user?
Yeah! But I could not afford to send my DX200TI back again to ibasso for uploading the unstable beta FW then get stuck and struggled like some of you did.
Now Now...let's try not to generalize. There are lots of iPhone users who like to tinker as well.Luckily I installed w/o a hint of trouble. Doing all this weird stuff, installing modded roms, side loading apps is bread and butter of Android. Thats why I guessed Iphone users may feel this is a tad complicated, I guess it may vary well be if your not used to this kinda of stuff.
Please try the DX200 with the stack AMP1. If it is normal then please contact me at paul@ibasso.com as the AMP8 may need servicing.
Well, Google took out soundfx library engine completely in Oreo ROM (saved me trouble in removing some manually in my Purist ROM). So, this plugin is out-dated in Oreo and your best bet is to wait until they release an update for Oreo ROM or newer with new audio effect engine.
Hello, how can software illegal? when I have applications on the google play store correctly paid! goes only about to access! OK, better will be for me sold DX200 and buy better Fiio with fully support and access to my correctly paid apps from google play store
I'm in the same situation streaming Tidal through UAPP with Tonebooster's EQ. Does this mean that when the official release of iBasso's Oreo ROM comes out it will still not have audio effects support for third party plugins?
I am in the testing process. Wipe data. Installed last official firmware. Installed Amp4. So far, so good. Now , after some more testing, I will reinstall Amp8.I think I have the same symptom for my recent amp8.
I have no problem with amp3.
I will test it with amp1.
You just demonstrated your ignorance: soundfx is still there! Take a look to /vendor/etc, /vendor/lib, /vendor/lib64.Google took out soundfx library engine completely in Oreo ROM (saved me trouble in removing some manually in my Purist ROM)
Installing your purchased app in Play Store isn't illegal. You can sideload adb or install apk from file manager directly. Trying to make google play services in unauthorized device is illegal. If I patch my ROM to make Google Play Services working, I will become illegal ROM cooker.
It appears to be that way. Maybe you can ask either iBasso or Tonebooster developer to update their products.
Regards,
Keetakawee
Hello, if it is a ROM only about access to google play store, similarly like it is other android devices, It is correct! that they are trying close, similarly than closed iPhone devices, is their thing... I want access and choose device, which ones allow it (Fiio). Now I wait and last chance for my iBasso is new Lurker Oreo ROM... if I fail to gain access, I sell the DX200 device and buy Fiio/Oreo with Google Play Store working.
