my dsd128 and 256 play ok in pure mango mode dsd512 cut out a couple of times
DX200=Affordable High End Audio. Dual ES9028Pro dacs. AMP1, AMP3, AMP5, AMP7 & AMP8 ***Firmware support now up for AMP9***
- Thread starter Paul - iBasso
- Tags
- at8ie ibasso ibasso dx200
MilesR
- Mar 22, 2015
Can anyone answer this for me. Can I hook up my external hard drive to my Dx200 with a usb-c to usb- micro b ? And can I transfer files over ?
You must have a friend/co-worker who has a PC, no?I really need to get a PC to proceed with the upgrade...
davidmolliere
Well, those who have a PC run Linux the other run Macs, such is the life in IT
![Headphone Smile :) :)](https://cdn.head-fi.org/e/headfi/smily_headphones1.gif)
- Oct 14, 2013
Roflmao....woaaa, why the hate of Windows ? Should I switch my Pc to Linux now ?Well, those who have a PC run Linux the other run Macs, such is the life in IT![]()
Fernando Goñi
- Apr 28, 2017
Hi,
I am having an strange issue with my DX208. I switch it on, after 2 minutes it switches itself off. That happens both in Mango and Android. Press the on button, everytime starts in Android mode.booting as if a reset would have happened. The battery drains itself 10% each time I restart the DX208. I have no idea why this is happening. Any suggestions appart from doing a Factory Reset? (it hasn't worked)
I am in the latest Lurker firmware
- Oct 14, 2013
Try the official firmware instead. Could be a bug with lurker firmwareHi,
If you still has the issue with stock firmware, your Amp1 can’t replicate the problem, then your Amp8 is likely defected
Fernando Goñi
- Apr 28, 2017
I have tried to install the stock firmware but the DX208 switches off in the copying phase. I'll try to change amps and see what happensTry the official firmware instead. Could be a bug with lurker firmware
Thanks!!
Interesting. Most of the IT people at my work use PCs such as Lenovo and Dell. Probably because my work uses all PCs.Well, those who have a PC run Linux the other run Macs, such is the life in IT![]()
cbeaumont001
- Apr 11, 2010
Does anyone have suggestions on less common ways to hard reboot the DX200? Holding power button for up to a minute, or holding play button then plugging in to computer produces no results. My device appears to be completely unresponsive after encountering a strange error while trying to downgrade from 8.1 beta back to 6.1.
@Paul - iBasso , I'll drop you the details in a PM so maybe you can help me troubleshoot.
I've heard the DX200's can't be bricked, so I'm hopeful I just need someone to suggest the right hardware override to bring it back to life. Thanks!
Press power and play button to get to debugging menu. Scroll to clear cache to see if that helps. Otherwise, you can do a factory reset.Does anyone have suggestions on less common ways to hard reboot the DX200? Holding power button for up to a minute, or holding play button then plugging in to computer produces no results. My device appears to be completely unresponsive after encountering a strange error while trying to downgrade from 8.1 beta back to 6.1.
Paul - iBasso
Sponsor: iBasso
Please try the DX200 with the stack AMP1. If it is normal then please contact me at paul@ibasso.com as the AMP8 may need servicing.Hi,
Stay updated on iBasso at their sponsor profile on Head-Fi.
Hi,
How long have you own your DX200 unit? I have the exact problem and my unit is more than a year old, i have to send it back to ibasso for battery replacement and everything works great now.
chungjun
- Nov 14, 2016
That plug kit is nice! I must get one! Exclusive to Massdrop? Is it an anytime purchase or have to watch for it to go up for sale?
Massdrop, you'll probably have to watch for it but I don't think for long, it'll probably be available again soon. There's MMCX version from MEE Audio directly too.
I got the 2-pin version from Massdrop here <https://www.massdrop.com/buy/69237#overview>
At a different color / finishing, the MMCX version is available (as a set) here <http://www.meeaudio.com/CMB-BAL-SET> and on Massdrop here <https://www.massdrop.com/buy/mee-audio-mmcx-balanced-audio-cable-with-adapters>
chungjun
- Nov 14, 2016
Hi,
Similar experience, about a year and a battery replacement gave mine a new lease of life too!
