A friend who has a Windows computer is going to help me update this weekend.
Waiting, waiting
#jealous
Waiting, waiting
#jealous
Hi. I was trying to install a new Android 8.1 but stuck. Need a little assistance.
Trying to run the 2.1 Android Tool exe, but my PC came back says "access denied"
What can I do? Thank you for your help in advance.
Did you unzip and extract the tool zip file to a folder on your computer? Also please check if the user id that you logged in with has admin privileges.
I simply had it downloaded from their web sight and it requires no user id input.Did you unzip and extract the tool zip file to a folder on your computer? Also please check if the user id that you logged in with has admin privileges.
I also find amp4s is the best amp ibasso made. The soundstage in that amp is stealar so good that visceral bass notes. Its just sweet candys.
Even better with DX200TI!![]()
It is not a problem of user but the settings of your Windows.I simply had it downloaded from their web sight and it requires no user id input.
Seems to work for many users but no all.....![]()
Yep, it doesCan anyone tell me if dx200 has adjustable lineout? Thanks in advance
My friend who has DX150 compared it to my DX200 and said DX200 is clearly better.(...)
I was thinking maybe I should try the dx150?
Because it has the velvet akm dac chips?
What you guys think?
Hmm I've tried everything you mentioned but in vain. I may try again with other PC . Thanks anyway.It is not a problem of user but the settings of your Windows.
1. Switch your Windows user to admin (or run the Tool as admin)
2. If it doesn't help disable any anytvirus software for 1h - it may be blocking access to "new/unknown" software.
