Update Log for latest FW.
Official Link:
http://ibasso.cn/?p=2272
Updated as follows:
01. Solved the Android system, the list loop, a small probability of playing automatically suspended;
02. Solved the Android system, long press the folder can not play subfolders songs;
03. Solved the Android system, From MangoPlayer switch to third-party APK player software, a small probability of third-party player silent problem
04. Solve the Android system, exit the player process notification bar still displays the music name problem;
05. Solved the Android system,
06. Solve the Android system, the song is played by the media pause button, a small probability of failure, there is a pause for a few seconds and automatically play the problem;
07. Solve the problem of scanning and then re-scanning the song scan, and optimize the scan rate; Android system, shutdown and then reboot, a small probability of reducing the number of songs, the need to re-scan the problem
08. Solve the Android system, some of the source song information garbled problem;
09. Solved the Android system, the list of artists Part shows the actual number of songs is inconsistent (part of the source is not displayed) problem
10. The system solves the Android, random play mode the song will be a high probability the same problem of continuous playback of the song;
11. solves the Android system, when the player using the fast forward, rewind function, fast stepping rate problems;
12 Solved the Android system, under the desktop or third-party APP to adjust the volume will block the status bar volume display (has adjusted the location of the original volume bar)
13. Solved the Android system, some of the source song when the progress bar Will jump to a random time to return to 0;
14. Solve the Android system, the equalizer settings are not remembered, there rebalance equalizer is turned off or inconsistent with the mode before restart
15. Solved the Android / Mango system, some of the audio source in the equalizer will be open error / restart problem;
16. Solved the Android / Mango system, DSD audio files greater than 2G probability can not play the problem of
17. Optimization Mango system, the continuous click on the next song, switch the song number is inconsistent and easy to Caton problem;
18. Solved Mango system, playing the entire ISO soundtrack file, in the song list or playback interface, click to view the song Information, there reboot or stuck problem;
19. Optimized Mango system, system information version number inconsistency with the Android system
20. Optimized the Mango system, left and right sliding fluency
