lantian
- Dec 14, 2016
Internal board on dx220 normal one though imagine max has the same size ones there.Did you mean the internal board to chassis screws on Max ?
Thanks
Hi Whitigir...wondering which 5 valves you mention was to be replaced? Was that canceled because of outdated or by other reason?Thank you to @bden59 for helping me to enable the EX modifications for DX220. The goal is to preserve bass slam, timbres density, further enhance them in controls, dynamic and punches, improving clarity, details, trebles extensions.
There will be 2 parts of the EX just like Dx200.
Disclaimer: by modifying your unit, you risk permanently damaging your dedicated player, and you are sure to void the warranty. Only proceed when you are ready to lose your player and take all the risk as a man wearing his pants **. To anyone who can and will perform these modifications, please keep in mind that it was developed for enthusiasts and by enthusiasts, so please keep the labor reasonable.
1/ part 1: Hardware Modifications
You will need
https://www.mouser.com/ProductDetail/80-T543B107K010TE150
3x of those
https://www.mouser.com/ProductDetail/80-T543B227K6AHW35
2X of those
https://www.mouser.com/ProductDetail/80-T520A226M10ANE080
2X of those
https://www.mouser.com/ProductDetail/80-T520A107M006AT
4x of those
https://www.mouser.com/ProductDetail/80-T527I476M06ATE200
4x of those
You will replace a total 15 capacitors and 5 different values
Layout is as in the pictures. Ask if any questions
Tips: in order to open up Dx220, you need to take out the Amp module. There will be 2 screws with 1 under the warranty label. Unscrew then, then use a sucker to split up the back from the side of the 2 screws. It will be a bit tough to get it in and out.
*tape the side buttons up* or else they will come loose and give you some funky business. Remember to take out the MicroSD
After unscrewing 4 screws, and remove ribbon cables (only 2) .... Lift the PCB from the bottom from side to side with a tweezer, be patient as there are cooling thermal plaster which keep it attached to the back chassis. Then push in the SPDIF uptop and take out.
2/ Part 2 is TDK noise absorbing sheets. You will apply it upon IC chips similar to DX200EX
Hello, it have been so long that I haven’t touched the Dx220 (the published details is the most recent one). I also never got around to those inductors as it was never damaged. You may want to ask Ibasso directly ? I think there were a couple members who had similar encounters and solved it, but I can’t remember exactly. May be they still reading the thread and give some insightHi Whitigir...wondering which 5 valves you mention was to be replaced? Was that canceled because of outdated or by other reason?
And I am also asking help on the un-labeled inductor's inductance... Cause i was screwed up 2 of that by squeeze more cap in my amp8...but i don't have any equipment to test those inductor...so if you can tell me that?
Hi guys, AMP8 excellent amplifier. I recovered a schematic for it
Accusilicon is not a brand name, but it has very respectable measurements and performances over other brands. Anyways, welcome to the fun parts of looking up for OC. When speaking about OC, there are ways more to take in consideration than just pull and replace.I am recently keep studying my dead dx220’s PCB, and try to figure out how they work and react between each others. ICs, caps, inductors, resistors, regs, transistors, op-amps.....until last week I had find something interesting on the oscillator.
Blue circles in alphabets are crystals without power supply, I had not research on them yet. Red circles in numbering are our main characters - Oscillator.
(Head-fi forbidden my for posting photo, because I am new??)
https://www.dropbox.com/s/m545srw9wvk5rx4/1.png?dl=0
https://www.dropbox.com/s/jql7cjjn313kulm/2.png?dl=0
Oscillator_1&2
https://www.dropbox.com/s/8setuzee4g9ihz0/3.png?dl=0
Oscillator_3&4
https://www.dropbox.com/s/5pt2suf3jlct4l7/4.png?dl=0
Oscillator_5
https://www.dropbox.com/s/8a906geaojq1vk4/5.png?dl=0
Search components by thier marking was bored and weary. Especially when it comes together with a disappointing result. I started with the most important part (OSC 1&2) which serves our ESS9018 DAC chips, but it was much more difficult than I thought. I had searched for days, but there was no result by marking, neither from google or china network. That makes me gave up on the oscillators and put my mind on other “easier” components for a long time.
When I come back to the oscillators part, that was already a month later. I did the search again, still nothing comes out. It was weird. Cuz I remember that the oscillators in dx220 was not a “nobody”, indeed that were a “sounds very famous brand’s powerful low noise oscillators”(not offence, I was so ignorance about oscillators and how they works, let alone those brands).
So I visited the official web site.
https://www.dropbox.com/s/70g5rs2g3vqbs42/6.png?dl=0
Now I have the brand, I search on google, no result but a barely empty official site, switch to baidu (CN network), search again, no result but a barely empty official site.
Search on Mouser : Nothing
Search on Dxgxkxx: Nothing
Search on XX Components : Nothing
At the moment when I thinking if the“sounds very famous brand" and the "powerful low noise oscillators” was kidnaped by aliens, I find a clues on the CN audio DIY forum. That was an argument about comparing 2 OCSs in audio usage. The first one was the most famed OCS brand’s star that I’ve heard many time when I search about OSC “Crystek - CCHD” And the second one is....AS318-b.
That’s much enough about the searching story. After that I realize this “Accusilicon” is not a leading brand in OSC’s field, not even a middle one. It was a PRC factory with a US address but nobody know them in US....and recently takeover by "XiaoMi". Beside that this company is more like a urban legend spread around audio lovers and DIYers in CN. by “Crystek - CCHD" beated quality with 1/3 of it’s price”. And I also find many CN’s DAP factory are now using this OSC.
Happy ending? Not yet, I’ve got my OSC with clear marking “AS318-v3P” but not “AS318-b”...... After research of ICs for months, I find a patten of the IC's part no. that normally, when a IC has a "B" at the end of part no. it means.....
https://www.dropbox.com/s/2vxuho1jg0kb47h/8.png?dl=0
As Expected (Thanks google translate for the easier quoting)
