The resolution of DX227EX is further sublimated by ECHU.
The sound is as delicate as silk and captures even the subtle afterglow when the sound disappears.
With KO-Cap and ECHU, the bandwidth is straight in a wide range.
KO-Cap is a replacement for high-grade tantalum Cap, but ECHU is a replacement for ceramic Cap, so it is separate from iBaaso's sound design.
It takes time to evaluate ECHU in EX.
PPS Film Cap can easily check the change in sound quality when it is used directly for signal lines such as coupling, but it is often used, but EX is adopted for the jack part.
As it takes time to repair the damage caused by the added heat, depending on the situation, please give about 300 hours for evaluation.
(The sound gradually turns clear and delicate)
Finish of DX227EX
The sound is gradually adjusted with the passage of time, but the sound balance of the amazing resolution is as straight as a measuring instrument.
It's not a pyramidal music balance that gives you comfort, so it gives the test to the pair Hp/earphones.
At the same time, you will get the opportunity to maximize your knowledge of the sound quality of Cap obtained by DIY.
If you have the patience of EX's devil's DIY charm, you can stop at KO-Cap to save time and enjoy music.
The DX227EX pair is a capacitor type KSE1500, so it forms the necessary music balance.
I used Nichicon KA.
Nichicon has a very strong 1-point relief audio Muse series.
Audio Cap has a peculiarity in sound quality, but Muse is not all-arounder and is the most difficult class to use.
I think that I would like to make the low to mid range a natural music balance with KA.
I think 470μF is a little larger capacity, but also aims to expand the dynamics at the same time.
The only concern is the claim that the highs are clean.
In about 100 hours, the whole sound was quite well-set, and the high-range rundown arrived calmly.
From now on, electrolytic capacitors will show their abilities, so I would like to listen to them as they are.
So far the power supply smooth part
Nippon Chemi-Con APSF160ELL471MHB5S 16V 470μF
Toshin kogyo (TK) 1CUTSJ221M0 16V 220μF
Nichicon KA UKA1 C 471 MPD 16 V 470μF
Is a combination of three.
The first impression of KA is the worst.
It sounds like a white noise-like server with a mistuned radio that does not seem like a high grade audio product.
The noise disappears after about 24 hours, and the volume rises slightly, but in about 50 hours, the high-range EX and KA sounds can still be heard separately.
