VanHai
Any opinions or information about these tubes, they are Mullard 5v4g. I have them coming next week, thanks.
Ok beginner question here.
I have observed a slight blue pulse in my rectifier upon powering up my amps.
It is very brief, after I hear the amp click on.
I have seen this on different rectifiers (Sophia, 596, CV711 and others),
and on 3 different amps WA22 and 2 separate WA6SE.
Am I correct to assume since this behavior has manifested across several configurations that its normal?
nothing to worry about: https://www.thetubestore.com/blue-glowOk beginner question here.
I am familiar with the “blue glow”.nothing to worry about: https://www.thetubestore.com/blue-glow
I will try to capture it on video tonight.1) I have not seen a blue flash on any of my rectifiers. It's possible they might be sparking, but unlikely. Any chance you can take a video so we can see what you're referring to? Is it possible it's the blue power LED blinking that your seeing reflected in the glass?
2) Yes, the Woo Audio WA6-SE Gen 2 that I have makes a click one things have heated up and are operationally ready.
3) Nice collection of rectifiers you've got... Any favorites?
Thanks,
Fred
It's not crucial - what I'm trying to determine is if it's plasma discharge or if it's possibly a glare/reflection from an LED that just happens to be reflecting in the glass.@ColSaulTigh
Of course my phone was not able to capture what I am seeing.
As I'm not keen on powering on/off unnecessarily, I'll try again tomorrow.
I was able to capture the “slight blue pulse” that I see in my rectifiers.
VERY slight, near the end, when the LED stops pulsing. Near the top of the tube.
It is quite a bit more noticeable in person.
I uploaded video to YouTube cuz I’m old and don’t know how else to share video here.
Has anyone compared the Raytheon and the General Electronics 1641 rectifier?
It is a very odd occurrence.Given that it happens when your LED stops pulsing, I'm inclined to believe that this has something to do with your Woo. I wonder if the Woo preheats the rectifier cathodes and only then applies voltage to the plates. So it might be worth trying to find out what your amp is actually doing while the LED is pulsing.
Again, in a different amp I have never seen this. And I have more than 50 rectifiers. Further, I strongly suspect that if your rectifiers were installed in my amp, there would be no "blue pulse."
The amps seem to function fine.
Nooo.I have a different amp (Glenn OTL) and well over 50 different rectifiers, and I have never seen a "slight blue pulse". I wonder if it might be a Woo "feature"?
