x7007
- Jun 30, 2012
Hi,I am really sick of those hair and dust that comes through the headphones, this is the second time it happened to me, I bought 2 new speakers from berdynamic and my friend did the work for me changing them. it worked fine and everything worked good till this day.
I test the http://www.audiocheck.net/soundtests_headphones.php
Poorly built or extensively worn headphones may start to rattle whenever loud or deep bass content is played. The next file scans bass frequencies and will literally shake your drivers when turning the level up. Adjust the volume in your headphone so that the test is made at a high level: the sweeping tone should remain pure and clear at all frequencies, without any parasitic buzz or rattle appearing in one earpiece or the other.
and it just have shaking rattling and parasitic buzz small and big.
I have second new Berdynamic 990DT just in case something like that happened. I tried everything from guides, cables, cleaning, it doesn't seem to 100% perfect and in my case not even 10%.
Is there any Quality headphones that has the exact or better quality without the hair and cleaning problem ? I could have bought already 1 headphones for the price of 2 headphones + speakers replacement for that price. now I don't want it to happen again, I use the headphones 24/7. without them I'm limiting to no use for gaming/movies/chat.
Please help with that, I want better quality than berdynamic 990DT , and WITHOUT the hair issues or cleaning.
I guess I prefer OPEN ones because of bass quality, or if there are headphone which have both advantages, means if its closed and has the bass like open headphones and such.
EDIT : By any chance if it happened to both speakers at the same time worn speakers ? Because I keep my headphones speaker at 50% and on the highest ohms 600 in Xonar phoebus settings. sometimes movies in games or logo movies have 100% volume set to them so till the game start it just have it on maximum volume, some movies are long or really loud, could this destroy my speakers after say 10 times running ? Because it happened on both speakers. I can't imagine that both speakers will have hair with same identical issues on the same time.
What is the safe volume to keep ? 40% ? 30% ? ------ 50% like I said is dangerous because sometimes it just doesn't follow it.
Thanks
Quality
Bass Shaker |
Thanks
