Majik Brownie
- Jul 22, 2016
EDM actually sounds pretty good on these once you get used to the sound signature.
Beyerdynamic DT 990 PRO Open Back Headphones (250 Ohm) on sale for $109 by ClassyU via NewEgg until 10 Sep 2016.
Thanks, just jumped on this deal.
Steve
Beyerdynamic DT 990 PRO Open Back Headphones (250 Ohm) on sale for $109 shipped by ClassyU via NewEgg for another ten hours.
[What does it take to become a paid shill these days? Don't mention that buyers should check the seller feedback, for one]
I'm trying to figure out how to get more from my DT990 pros and if an amp and DAC would do the trick.
I've had my DT990 Pros (250 ohm) for about 4 years now. I got them with the intention of gaming (Playstation) and music. However, I never really fell in love with the sound for music. Perhaps I didn't give them enough of a chance and gave up too quickly. For gaming the've been great. They are so comfortable that I could wear them all day if I wanted to. I've had them amped with a Fiio E09K since I've had them. Now I'm not an electrical engineer so when I see reviews using impedance and amps and ohms it all starts going over my head. Just looking at the numbers it would seem that the E09K was enough to power the DT990s, but they never really popped in the sound department. Everything has always seemed understated and distant. I mostly listen to rock and metal. Not really extreme metal, but styles that are closer to hard rock and perhaps some thrash. Perhaps it's the scooped mid sound that I don't like, or maybe it's a lack of power from the amp. The music I listen to typically needs some thumping mid-bass and the mids add tone to the music. Scoop them out too much and the music kinda loses it's personality, IMO. I really don't know, these are my first and only set of "good" headphones.
Now I know the Fiio E09K was a budget solid state amp when I got it. I read it was enough to power the headphones, and it does work. I just don't know if there is a better option that would help me the sound come more alive, or perhaps a better DAC in addition would help. I've been eyeing the Schiit Bifrost off and on for a couple years now and never pulled the trigger. Then I started thinking that maybe an amp and DAC together would help give some substance to the headphones. Maybe something like a Bifrost 4490 and a Lyr 2 (or Valhalla 2). I was leaning to Schiit amps because I was pretty set on the Bifrost and I like the matching style and footprint of their amps, that's not to say I wouldn't be open to other or better suggestions in the price range.
So after that long winded post I guess I'm asking for opinions on where to take my setup from this point. Should I stick with the DT990s and add an amp and/or DAC and maybe even an equilizer? If so, any suggestions? Or would I be better suited to try to find headphones that maybe have a signature that is more my style? And if that's the case does anyone have suggestions? I don't travel with the headphones, so they don't have to be closed and they don't have to be low impedance. However, they do have to be full sized, over ear style and comfortable to wear. I hate headphones that push against my ears. I find the DT990 incredibly comfortable and if I were to get a new pair I wouldn't want to lose that comfort.
E09k should be very good with the DT990 250. It's probably hard to improve on much around that price unless going in a different direction like tubes, which you may or may not like. For power, I'd question the E09k if you had the 600 ohms, but 250 is much easier to drive.
If you're willing to EQ, add some DBs to the mids and see how you like it. Even 1-2 db across the range can have a surprising change. The recessed mids help create a sense of space, but that also means you don't have as good of an in your face effect.
Did I miss you saying what DAC you currently use? Is the onboard of your motherboard being used for a DAC? That would likely be alarm bells to me of what's mainly holding back a better sound. (A different DAC still is unlikely to help the scooped mids "problem" though.)
