Delphiq
- May 4, 2012
I really don't blast it. i meant that at very low levels it goes away.
I tried running my ipod output through my headphone amp and it ceased.
However, I have tried 3 different USB soundcards through my computer and it persists. Quite strange.
I once tested them on my brother's desktop on his Asus Xonar DX and there was no rattle!
The Xonar DX has very high output impedance, that probably changed the bass response, and the different resonance might have avoided the rattle by luck (or it was simply not the same volume, or just a random coincidence that the drivers happened not to rattle at that time). Rattle problems are most commonly caused by hair getting into the drivers, and they can be somewhat random.
I have this same issue with the DT990s, I have the 600ohm, and was at this point thinking it was the fault of my soundcard. Still could be, either way it just bugs me.
Sorry for bumping a somewhat old thread, but this is annoying, and nice to have finally found out it's not just me.
Left side for me, rattle happens more when not much is going on on that side, or when there's really low bass. Have also checked for hair.
Gonna switch out to Titanium HD soon, will keep using the E9 with them though. If I still have problems, I may just look into grabbing something else, as
I've had these for a few years, and that's as good a reason as any to seek out something better/different XD
Can you tell if it's a rattle or blown driver? If it's all but the lowest volume, and it never happens on one side and nothing is loose, driver is probrably bad.
