Jun 14, 2012 at 1:59 PM Thread Starter Post #1 of 5
Karido
I'm a noob and this is my first phones.
I will be getting the Beyerdynamic DT 770 Pro-80ohm.
After reading about amps and ohm I found out that my mixamp (Astro Mixamp Pro)  will do 70mW 32ohm per channel. is that good enough? and if its not, would someone kindly recommend a good amp to close the gap and be able to use the phones to the fullest?
The amp will be used with the mixamp. I have my PC and Xbox360 hooked to the mixamp and those are the only sources I'll use the phones with.
Thanks.
Jun 14, 2012 at 2:11 PM Post #2 of 5
After reading about amps and ohm I found out that my mixamp (Astro Mix-amp Pro)  will do 70mW 32ohm per channel. is that good enough? and if its not, would someone kindly recommend a good amp to close the gap and be able to use the phones to the fullest?
The amp will be used with the mix-amp. I have my PC and Xbox360 hooked to the mix-amp and those are the only sources I'll use the phones with.
Thanks.
The Mix-amp. might do a decent job of powering the DT770 Pro 80-Ohm
Headphone amplifiers.
SMSL SAP-100 $70 on eBay
Fiio E9 $115
O2 (Objective 2) $155
On eBay there are assorted single tube headphone amplifiers sells from $50 -$130.
Amazon has one for around $63.
Little Dot 1+ Hybrid $160
Jun 14, 2012 at 2:15 PM Post #3 of 5
Fiio E9 $115
Thanks alot!
but they are kinda expensive.. ):
Wont the Fiio E5 or E6 work?
I'll have them shipped to the Middle East so Ebay is a no no. My only place is amazon.
Feb 8, 2017 at 9:12 AM Post #4 of 5
Guys, hi! I'm new here, and i can be considered as a noob.
I have the same problem, because I'm a passionate gamer and audiophile.
After tons of research, i narrowed down my choices to either the Dt 770 32 ohms or 80 ohms.
I game on my ps4 (with an optical port) and i have the s7 edge as my phone.
the problem is I don't know which set is better. I need the set of cans which will satisfy both my need to listen to music and gaming.
So is it better to get the 80 ohms version with an amp? (and i need help to find an amp compatible with the ps4)
or should i get the 32 ohm version?
Please help me out! Any reply will be highly appreciated!
