Joe Bloggs
Sponsor: HiByMember of the Trade: EFO Technologies Co, YanYin TechnologyHis Porta Corda walked the Green Mile
Joe
I have been posting in the K5 post about the damage it has caused my 5 month old X3ii. Prior to me mounting my X3 in the K5, the micro usb port was great with no issues. After trying to get it mounted into the K5, the port is now damaged to the point that I have to wiggle the cable around for the t PC to recognize it.
Insertion of the X3 into the K5 was never an easy task.The usb ports do not line up due to the difference in back spacing compared to the X7. You have to wiggle it around until you can pry the usb jack on the K5 back against the spring to insert the X3. This has been documented by a few headfier's here at that post. This is where the damage has occurred.
It never worked in the K5. The X3 would recognize that it was docked and start charging, but it would never be recognized by the PC. I tried different usb ports on my computer, tried different usb cables and made sure the X3 was seated all the way down in the K5. I never used a case or a spacer in my K5. I even sent the K5 back for an exchange for a new different one, thinking it was a defective K5. However the new K5 performed exactly like the old one that I sent back.
The other issue was that if i tried to play music from the internal SD card while in the dock, I had little to no output on the left channel to the headphone jack.This was the same situation with both K5's.
My concern is that the X3's usb port is now damaged and I do not know how long it will keep on working before the port becomes useless and I have a $200 paper weight.
I have contacted Fiio support via email. I emailed them on 2/18 with this issue. They responded about if I used a case or the spacer which I did not, I replied on that day and am waiting for a further response
I've been told that you have been instructed by technical support via email to send your X3 2nd gen back to them for repair.
You may let me know via private message of any further developments
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
