I'm the OP.
Would you like to weigh in on my first post?
The short answer to the OP, in my opinion, is you can't over generalize such things. Words like "all" or "always" are usually pretty easy to dispute as it's not hard to come up with exceptions.
But if the entire design has been engineered to some reasonable point of diminishing returns, and everything is literally "good enough" (which doesn't mean expensive), then it's very likely in a blind test you won't be able to tell one DAC from a similarly well engineered different DAC.
There are many examples that demonstrate this. Meyer & Moran, for example, published a landmark AES study involving over 500 listening trials over a year including members of an audiophile club, recording engineers, and students with especially acute hearing. They played high resolution (DSD) SACDs on a high end system and sometimes, unknown to the listeners, switched an extra 16 bit 44 Khz A/D and 16 bit 44 Khz D/A into the signal path. At any realistic volume setting (to not expose the higher 16 bit noise floor during silent passages) NOBODY COULD TELL THE DIFFERENCE!
The above study says a lot. It proves you can put a whole bunch of extra hardware in the signal path, and as I said above, if it's sufficiently well engineered, it doesn't change the sound enough for anyone to detect it's even there let alone what it "sounds" like. The A/D and D/A had nearly everything on your list but nobody could tell when all that was added to the signal path.
While those who like their expensive DACs, SACD players, etc. naturally tried to dispute Meyer & Moran. The critics, as is often the case, didn't provide their own study to prove Meyer & Moran wrong (even though they could have easily funded one from all the commercial SACD interests watching their entire market being debunked). They mostly just tried to take pot shots at them and throw rocks. Meyer & Moran even responded to the critics in a follow up AES paper and proved many of their concerns wrong. There are links to all this on my site in the subjective debate article.
So can all those things on your list sound the same, even for very different designs using different parts, yes they can if you define "sound the same" as "nobody can hear a difference in a blind test".
