In which case, simple 2 steps:
1. Blind test to determine the difference does actually exist. I personally can attest to hearing giant differences in bass impact, treble extension and even soundstage thanks to a combination of bias and volume mismatch. It astounded me at the time that such enormous differences would disappear so readily. Whilst anecdotal I would draw your attention to the infamous Stereo Review article on amp sound - when sighted-testing the amps even the self-proclaimed skeptics, who had declared they would sound the same, were amazed - the entire group agreed there were audible differences. These completely disappeared under blind conditions (not DBT, just not knowing what they were listening to).
2. If you determine the difference is real, take the superior-measuring piece of kit, so you have a more neutral base, and use source tone controls/EQ on PC/Separate hardware EQ to colour it to suit your preference.
Me too. Differences completely disappeared.
the infamous Stereo Review article on amp sound....
Ah, the infamous SR amp test..... it was a historical landmark for the demonstration of placebo effect.
Still, I wonder if the $12000 Futterman monoblocks really sounded like or
measured the same as a cheap Pioneer SS receiver with a slide volume control.
(see below)
It would be an illusion.
Noise cannot increase resolution it reduces it, crosstalk does not improve stereo image it reduces it, a high frequency boost creates an artificial impression of detail but it is lower fidelity by definition.
All these artifacts and others can create a pleasant illusion. The defects in vinyl playback (may just possibly) do the same. If you like that sort of illusion that is fine and of course a matter of unasailable preference and you can on most parameters add these pleasant defects if you wish, not sure about adding crosstalk in speaker amps ? - but it is still lower fidelity.
The problem comes with the phrase "sounds better" - even hardened digital types can be woo'ed by the sound of vinyl even though rationally it is a far less accurate transfer of the master tapes (more distortion, more noise, relatively large speed variations, variability at different points in physical playback, hum, rumble, hiss, RIAA bodging) - does not mean it cannot sound very alluring. To this day I still want to get a turntable (again) even though I know rationally it is a daft idea
In Psychology there is a thing caled the Halo effect - if we like something on one attribute we often also ascribe other positive attributes to it even if they are not true.
Nicky, Nicky, Nicky,
how can I argue with anything you've said.......
But placebo and illusion is not what I'm talking about.
Would you be ready to step forward and declare that the new generation of 32 bit ESS Sabre
DACs sound no different from my DAC-AH
DAC?
Or, is it possible that the 32 bit chips actually sound different? Is it possible that they have, as claimed, more resolution? Is it possible that the sound is actually be clearer or cleaner? Is it possible that the stereo image be better?
Sounding better is a very important thing. It is arguably why the 650 superseded the 600 in the Senn. line, and the old argument of why not just EQ applies here as well.
I really dislike arguing against placebo et al. But I've come to realize that everything does not sound the same. There is too much variation in design and component selection for that to occur. Sure, a lot of things that measure the same, might sound quite similar, but, not everything measures the same, or sounds the same (even with similar measurements).
It's not enough to say "it measures badly" or
Noise cannot increase resolution it reduces it, crosstalk does not improve stereo image it reduces it, a high frequency boost creates an artificial impression of detail but it is lower fidelity by definition if the sonic result "sounds better" as it did for the guys who bought the Carver amps or the guys who prefer tube equipment or the Wadia sound.
I'm also not convinced that everything that measures good sounds the same. My little Fuze measures pretty well but played through any of my amps, it doesn't sound as good as what I can get from my computer rig.
Here are the measurements for the chip in the Fuze, (which btw, does volume digitally) What do you think?
