does anyone no work I can get spare parts for my audio technica 900-lte
post-7588165
Thread Starter
Post #1 of 8
ellover009
does anyone no work I can get spare parts for my audio technica 900-lte. I think thats the right model. I need the complete wing that rest on the head from one side, maybe new cushion for the other side and if the leather is cheap enough that too.
post-7588298
Post #2 of 8
Digital-Pride
Have you tried contacting Audio-Techica's customer service?
post-7588400
Post #3 of 8
ellover009
Thats a good sugestion but dunno if theyll sell me parts from a non usa designated product. Last time i called went through automated system, ended up at some voice mail and they never got back to me. Called em twice in past.
post-7588658
Post #4 of 8
warubozu
I think the model you're referring to is the A900LTD. You can check with Audio Cubes 2 for the 3D Wing pads as they do carry them in stock. As for the 3D Wing itself you may have to try Audio-Technica USA. The 3D Wing assembly for the A900LTD is exactly the same as the A900, A700, and A500. The A500 is sold the US so AT US should be able to help you. Just tell them you need a replacement 3D Wing asssembly for the A500 which is available in the US, the wing pads doesn't come in leather.
post-7588839
Post #5 of 8
ellover009
I dont mean the wings in leather but that leather like material that they have in the ear things. Or if i knew of some chemical that can be used to clean them to give it a more neutal scent. Some other things have been used to clean them but i want a neutral clean scent so that it doesent overpower my scent. Kinda like put em on, they clean but they also mine.
post-7588916
Post #6 of 8
warubozu
I know what you're trying to say, At and neither does anybody else that I know of makes a leather covering for the pads that fit onto the wing. Not sure what to use to clean the spandex like material and foam inserts of the wing pads and yet leave a neutral smell.
post-7589013
Post #7 of 8
ellover009
ok so I managed to get in contact with someone at audio technica, they replaced the 3d wing for free, and I bought new pads and ear cushion, the only thing I think I forgot to order was the cloth like material thats on the inside.
post-7589082
Post #8 of 8
warubozu
That cloth like material you mention is part of the earpads.
