Do SENNHEISER HD25-1 II isolate and keep sound in well?
Head Injury
- Sep 11, 2009
- Messages
- 5,404
- Reaction score
- 438
They isolate at least as well, if not better. If isolation is a priority, though, consider IEMs.
classified01
- Sep 10, 2011
- Messages
- 17
- Reaction score
- 11
I'm a over-ear full size user, but how about leakage? Any reviews on how well it keeps sound in?
Not if you're referring to the Beats Solo.
This is known as an on-ear design. "Over ear" might sometimes be expressed as "around the ear"--which is literally what the proper term, "circumaural", means.
Solo is on-ear. HD 25-1 is on-ear too.
Also: when you say you can't find reviews on the HD 25-1 isolating, you didn't search the forums, did you?
http://www.head-fi.org/search.php?search=hd+25+isolation
Aizura
- Mar 3, 2010
- Messages
- 728
- Reaction score
- 57
The HD25s are actually quite famous for their amazing sound isolation. I bet they'll isolate even better than the Solos.
rowett
- Sep 13, 2011
- Messages
- 17
- Reaction score
- 0
i used HD25s at work every day for years and only ever had one comment about leakage (and i was seriously blasting it)
jasonb
- Sep 14, 2010
- Messages
- 4,385
- Reaction score
- 878
look into the AIAIAI TMA-1's as well. they are another good looking can similar in size to the HD25's. The TMA's are said to have a bassier and darker sound than the HD25's. They'll probably sound a bit closer to the sound signature to the beats. The TMA's isolate well and leak very little.
yd2zhang
- Jun 15, 2011
- Messages
- 154
- Reaction score
- 14
How bout some fanny wangs? That way you get both style and quality (sorta)
twiz 8
- May 21, 2011
- Messages
- 49
- Reaction score
- 10
I own HD 25 1-II I have noticed amazing sound isolation, seems to be close to par campaired to my W2's. I have been using the pleather pads how does the sound isolation to the other softer pads (my dog is not going to be able to tell me tonight).
