This is the Sound Science forum, remember? And in here, such comments are meaningless.
And that "same level of copper you can buy at Home Depot" is used by the military, the aerospace industry, etc. It's used in the most sensitive instruments made.
You keep using terms like "crappy" and "copper you can buy at Home Depot," but you continually fail to quantify these statements with anything meaningful. It's pretty clear by now that all you're doing is denigrating that which you know nothing about.
Again, until you can offer up something meaningful instead of just repeating the same nonsense over and over, I suggest you refrain from using such terms.
se
I don't get why you are having such a big issue with this. Do you accept that copper grades exist? Or are you trying to imply that all copper is the same?
"The first family, the coppers, is essentially commercially pure copper, which normally is soft and ductile and contains less than about 0.7% total impurities. Commercially pure copper grades are designated by UNS numbers C10100 to C13000. The dilute copper grades contain small amounts of various alloying elements that modify one or more of the basic properties of copper.
Electrolytic tough pitch copper C11000 is made from cathode copper, that is, copper that has been refined electrolytically. C11000 is the most common of all the electrical copper grades. It has high electrical conductivity, in excess of 100% IACS. It has the same oxygen content as C 12500, but differs in sulfur content and in over-all purity. C11000 has less than 50 ppm total metallic impurities, including sulfur.
Oxygen-free copper grades C10100 and C10200 are made by induction melting prime-quality cathode copper under nonoxidizing conditions produced by a granulated graphite bath covering and a protective reducing atmosphere that is low in hydrogen."
From Paul at PS Audio:
Professor Atsumi Ohno began the study of the solidification of metals in the mid 1960's, and published his landmark book, Solidification; The Separation Theory and its Practical Applications, in 1984. In this book, Ohno describes his many theories and concepts regarding the processing and solidification of molten metals, and the resulting crystal structures. He goes on to describe his unique process for casting metals with virtually no crystal structure, the O.C.C. process. This concept was first conceived of in 1978, and utilizes heated molds in a continuous casting process. Eventually, international patents were granted for O.C.C. (Ohno Continuous Casting).
The copper produced by this method is small rods of O.C.C. pure copper, from which wire can be drawn and which can have Copper grains of over 700 ft in length. A Japanese manufacturer is currently using this process and produces O.C.C. under the trade name PCOCC (Pure Copper by Ohno Continuous Casting).
Some type of continuous cast copper is generally what you find in high-end copper cables. Incidentally, according to Paul they measure their cables with time-domain reflectometers.
