budx3385
- Nov 7, 2005
Hi. If you dig back in the early pages of this thread, you will find my comments on this question. Basically, I found the cryo'd 6BQ7a that I purchased for $25/2 from tubeworld to be much more transparent, detailed and true to timbre than the stock driver that came with mine. But, if I recall correctly, there were others who felt that the 6N1P-DR is a better tube, especially if made in some city they named. I assume they found it on ebay.
Yes, Donald did OK this swap. Rolling all three tube types made an audible difference here.
Have any of you found that the 6N1P driver to take a long time to smooth out?
I ask because I have an assortment of used 6BQ7A tubes. All of them sound "better" to me than the 6N1P. The "tone"/"liquidity" of the 6N1P on classical and rock guitar music (Julian Bream, Mark Knopfler and David Gilmour, mainly). is just "wrong" compared to the 6BQ7A. It's treble on female country music singers is jagged, sound almost sibilant. It seems to lack "the drive" of the 6BQ7A everywhere in its frequency range. The tube is more detailed than the 6BQ7A, but not greatly more so.
Now, if you compare the construction of various versions of both in almost every case the 6BQ7A looks exactly likely what is, a cheap TV tube of dubious quality, while the 6N1P has a much more complicated structure and (with the exception of a couple of mil spec 6BQ7As) looks like what it is - a durable military signal amplifier. (I'm not exactly sure how it fitted into the Soviet arsenal).
So, has anyone noticed that the Russian tube takes a long time to settle in? I'm getting impatient.
By the way, the 6BQ7A is not an exact electrical drop-in for the 6N1P, but i see that the heater current is the same, which is NOT the case for 6DJ7/ECC88. My understanding is that Donald has OKed the use of this tube as a replacement, meaning to me it will do no electrical damage.
Finally, I was surprised that the driver could make such an audible difference.
