GBC Enhancement Wraps - Tonal or body weight tuning and misc. install comments
I installed two more of the wraps, SPDIF cable (that was modded to include a GB cable) and DAC analog RCA output. Something I forgot to mention previously is tonal or overall presentation weight can be tuned. Will also effect how upper frequency is presented. Adjusting one cable wrap can do this. If you look at the pic included, the closest wrap is spiraled around the ground cable so the spiral is closer together than the one to the left of it. Not that it matters but the one to the left goes to the BNC digital input of the DAC.
So here is how it works: The closer together the wrap is spiraled around the ground cable adds weight to the overall presentation. The farther apart the spirals are the more accentuated the top end is. You can adjust the wrap and hear it change real time. Kind of crazy since the ground cable is not in the signal chain. Once it sounds right to you, let system settle with this new setup for an hour or so before messing with/tuning it any further, so you have a new baseline.
Misc. install comment:
* Once you start to get a few of these wraps installed, you will want to play around a bit with adjusting the wrap spiral(s) as mentioned above. This is to get the tonal presentation the way you want it.
* 2 places that sounded a bit off to me:
- Was minor but my headphone system is so sensitive and resolving I can detect any tiny change. I did not quite like a wrap installed on the PC power cable (Nordost Odin 2) that has a ground cable on it. I may play around with placement and spiral adjustment later.
- The Nordost Odin 2 XLR balanced cable modded to add a ground cable. This cable is a pair (left and right). I tried two wraps at the box, 2 at the center, 2 at the outputs of the DAC, I did not like any of these installs. I tried one at the box and that was ok, but sounded a tad off. So unfortunately, at least in my system is a no go.
I have 7 other places in my system to try LOL, which I will in the next few days. Will mention anything to note.
For anyone that has several ground boxes already properly installed in their system, they will understand the following. Remember how after the installations of the ground boxes, it transformed your system? Happens again after these GBC Enhancement wraps. System will again leap forward in performance. Like before, it is not subtle.
