Ghoostknight
long time i did not write here, but here are a few new things i discovered:
https://www.qummulator.com/wp-content/uploads/2017/02/Scalar-Wave-Theory-And-Experiments.pdf
Scalar Waves were discovered by Nikola Tesla, they travel even faster than the Speed of Light and you can produce them with two signals with opposite phase
i bought an small stereo amplifier where you can hook up an usb stick with music files, created a file with all solfeggio frequencys and 9999Hz (and 99,5Hz which is accourding to Dr Rife against harmful EMF) and Left Channel is correct phase and right channel inverted phase, bought a speaker cable like this:
https://www.amazon.de/Lautsprecherkabel-Boxenkabel-Audio-Kabel-Hi-Fi and without connecting the other side put left and right channel on each cable and wounded it (clockwise) around a Bambus rod (which forms a kind of tesla antenna), while the magnetic/emf field around the cables should simply cancel eachother out, its this cancellation that actually produces Scalar Waves
https://eolix.fr/en/the-9-solfege-frequencies-in-cymatics/
Lhakovsky MWO Antennas (which are on the backside of the above posted plates, the Scalar waves produced by the Lhakovsky MWO side "aggregate" the other side which is tuned for example to solfeggio frequencys):
https://de.aliexpress.com/item/1005008801896126.html
i also wait for this one: https://de.aliexpress.com/item/1005007982286258.html
think of it like this, it will pick up any EMF in the room and radiate it again trough this specific flower of life (golden ratio) pattern which also should in theory "harmonize" the room
Happy Experimenting!
