GBC Enhancement Wrap - Parts list, Construction
Parts list:
There is not much minerals used, it is not needed. Actually using more has a negative effect. Here is what you will need:
* Cling wrap or Glad wrap, see pic for this household item. You will know what this is. I am using 12" wide version.
* Velcro
* Scissors to cut the Velcro
* Plastic spoon to measure minerals (my favorite measuring tool LOL)
* Magnetite
* Rochelle Salt
* High grade Graphite
* Tourmaline powder (I am using Brazilian Tourmaline powder)
* Vinyl if you want to wrap it like I did for esthetics. I will show you what I got and from where. I recommend a thin black vinyl, one that you can remove the backing. With the backing on it added a dielectric that had a audible negative effect. Once I removed the white backing, which just pealed off, the vinyl itself did not have a audible effect.
Construction:
STEP 1) You are going lay a piece of the cling wrap of about 13" long on a desk or table. Exact length is not critical, you just need it long enough. I used about 13" in my three final wraps. See 2nd pic.
STEP 2) Start laying the following ingredients in the order listed and the amounts listed length wise like in the pics. Once you have all the minerals placed on top of the cling wrap lightly mix the minerals. When laying out the minerals on the cling wrap do it slowly so you do not create dust you will be inhaling. See pic 3.
* Magnetite - 5 parts (5 parts= one flat spoon full)
* Rochelle Salt - 1.5 parts
* High grade Graphite - 1.5 parts
* Tourmaline powder (I am using Brazilian Tourmaline powder) - 2 parts
STEP 3) Lightly mix minerals. Keep in the same area you see in pic 3, you will be wrapping all the minerals together like a burrito next.
STEP 4) Take the cling wrap below (at bottom) the minerals and fold it over the minerals, pic 4. Then fold the mineral mix over two more times. You want the final burrito roll flexible so keep the width of the burrito about 1". Then fold the sides over so there is enough of the cling wrap you can double fold the sides. We want a thicker side to prevent breakage. see pic 5.
Now roll the burrito all the way until there is no more cling wrap. See pics 6-8 for clarification of what you want after the burrito is all wrapped up. If it is .5" shorter or longer is fine, do not sweat that detail.
Not sure how many pics I can put up so "STEP 5" in next post/to be continued.
