cdacosta
this video just released which contains some talk about grounding boxes, in the video the guy explains that the best way to connect a grounding box is actually measuring between the iec socket ground and finding a spot which has the lowest resistance to the power inlet socket (which might even be a chassi screw instead of for example rca ground)
has someone tried this?
With due respect, the Shunyata rep is not referencing use of a passive ground box filtering device like I use or write about. They are speaking about ground devices to minimize ground differentials between components. Totally different devices that do different things. Based on the speaker's descriptions of the Altera devices, the binding posts in the units terminate to a single ground plane and each binding post has its own filtering. The filtering is to help isolate noise and likely is using caps to filter different frequency bands. Several designers from the early 2000 era have been using and experimenting with this concept. I have several in my system that was designed in the 2007 - 2010 or so era that I was helping/took part in prototyping across about a year. Works to help smooth AC sine wave and filter out very high frequency noise. It works, is audible, but no where as effective as filtering noise from signal ground. With that said, Shunyata also uses minerals in their designs to filter noise in their products.
I do 100% agree with the person being interviewed from Shunyata, that the internal component noise is distorting and masking information on the recording. And this distorted signal is being transmitted throughout the signal chain. About 2-4 weeks ago I wrote about what I found in regards of passive ground box filtering and the results with different installations. This is applicable with the passive ground box filtering, not star grounding to a single place to minimize ground potential differences.
