cdacosta
Link to this wire so I can study it?2.5 mm stranded (7 S. Silver cores) Xangsane
Yes. I had to use it on both ends this time (Monosaudio RCA and Viborg banana plug)...Are you referring to Mundorf solder?
https://www.aliexpress.us/item/3256801840926381.htmlLink to this wire so I can study it?
Great idea, have not tried the wraps on my video monitors.I installed the DIY cable wraps on my cable feeding the power strip from the wall socket. That cable is a real Furutech Nanoflux (non NCF version) with a noise filter in the middle of the cable. That noise filter is the place where I wrapped the bags around. I used these Ikea bags…
There are small and big bags in the box. I filled the small one 3/4, closed it and double wrapped it with the bigger bag, then I placed the bag under the power cable. Next I made another bag in the same manner and placed it on top of the cable.
The complete weight of the cable wrap…
Installed it looks like this…
When listening I took away and reinstalled the bags at least five times to make sure I wasn’t imagining things. The effect is more than subtle but less than ‘wow’. I heard a deeper and more realistic soundstage. I tried it on different locations on the cable but in this way was the best.
I also used a magnetite bag on my tv cord, where the effect was at least as big. That ac cord is a normal 2-prong cord.
Yes absolutely, it has improved a msrp €3500 cable. Yeah, a ground box delivers more improvement and to say it is three times better would not be far off.Great idea, have not tried the wraps on my video monitors.
So for the power cables you tried these DIY AC wraps on would you say they improved the performance of the power cable?
For me, the effect is about 1/3 of a ground box. How would you compare the effect vs a ground box?
Glad to know you tried the wraps and shared your experience with them. For a few dollars, and a few mins to make and install, they are a nice tweak.Yes absolutely, it has improved a msrp €3500 cable. Yeah, a ground box delivers more improvement and to say it is three times better would not be far off.
I can’t really see difference in picture quality but it does improve sound quality on my tv.
Interesting, when I have more time I will goof around and try different applications. In coming up with using Magnetite with the AC cable wraps I noticed the effect is very different than using magnets. The basic concept is to break up the magnetic field generated by the flow of electricity. By breaking up the magnetic field the electrons flow is improved. Magnetite just works better in this application than anything else I have tried so far.So I went with a new idea of placing a large slim bag of magnetite powder under my power strip to see if it does anything positive. This is my secondary power strip for mainly non-audio accessories. My main system is fed by a multi-thousand dollar power conditioner, Aliexpress aftermarket cables and a few cable wraps.
Being a mainly non-audio AC path, I was surprised this made a difference! Details are popping out with even more life than before and quite a magic vivid organic experience! This is of course on top of innumerable of other system tweaks.
Do note this is a magnetic compound so I would discourage placing it any closer to components with complex circuitry of any kind. And I have already moved that power supply shown farther away from the bag that you see.
Instead of connecting to the ground pin of the xlr, have you tried connecting to the negative on the xlr, the same as RCA connector ?Tips and general guidelines on modding cables to have a ground box cable to attach to a passive ground box.
* I recommend modding cables you already like. By adding a ground box to filter the cable (and usually also component output stage or power supply), will only improve on the performance of the system. I have yet to experience any negative effects of filtering a cable. I have also never experienced the mod to do nothing. Meaning the modded cable has always improved system performance.
* Remember to allow time for burn-in of the new cable (wire and connector) and ground box to settle in. Likely immediately you will hear a sonic upgrade, but takes time for it all to settle in.
* I recommend the first cable to mod is the main interconnect between DAC and amp. This is a system transformative mod.
* When modding an interconnect (XLR or RCA) or digital SPDIF RCA, use one 14ga. 6N copper OCC stranded wire for the cable. The ground box cable is wired to Pin 1 (ground) of the XLR and negative on a RCA connector. Add the ground box cable to the source side of the cable. This way the output stage of the component and cable is filtered.
* When modding a power cable, add the ground box cable to earth ground on connector. For power cables use the dual twisted (11awg) 6N copper OCC stranded wire. Add the ground box cable to the side you want to filter. Does not matter if the power cable has a shield, whether it is a floating or connected shield.
* Use Furutech Nano Liquid if you have it.
* If you want a more professional look and want sleeving for the ground box cable, use cotton sleeving. PET sleeving or Techflex will add a slight smearing effect.
* I recommend to only use solderless connectors for the mod or ground box cable termination. Solder will degrade performance. The clone Furutech solderless RCA, banana, spade and FI-50 connectors perform well, are easy to work with and are inexpensive. See included pics of the cables that I modded for examples of finished cables. These cables are in my system.
I have not tried that. I did it like Entreq. Even though using Pin 1 (ground/shield) works beautifully, I would be interested in knowing the difference. Have you tried it?Instead of connecting to the ground pin of the xlr, have you tried connecting to the negative on the xlr, the same as RCA connector ?
there is no negative like on chinch, ground on xlr is the equivalent of ground on chinchInstead of connecting to the ground pin of the xlr, have you tried connecting to the negative on the xlr, the same as RCA connector ?
